Speedometer Calibration
Thanks guys-
Kinda figured the gear was correct based on the accurate odometer.
For as long as I've owned the truck, the at rest needle was never visible- dropping below the "0" mark at a standstill. I recently fixed that easily enough Here and thought it would be fixed. No such luck. I can continue to add 7mph as I've always done I suppose!
I have Speed Hut gauges. I like that you can pick from an array of different combinations of design and colors. The GPS also tells you elevation and will tell you your quarter mile time if so desired. They are also very helpful and in my opinion reasonable. I fried my wiring when a friend of mine tried hooking them up and he hooked a ground to a hot by accident. I sent the gauges back in case they were fried along with the wiring harness that came with the gauges. They sent me a new harness and replaced the board that got fried. They charged me $15 total! I will always be their customer.
BTW, they are made in the US too.
Ok, is that the 4" set and if so did you have to alter the original holes for them to fit? Is that the antenna on the dash above?
Take your speedometer out of the dash. Clean and lightly oil the visible moving parts. There is probably a small cap or cup over the bushing that your speedometer cable drives, oil the wick or remove the cup and put a drop of oil in the hole. Do not get any oil in the end of the cup that drives the speedometer needle.
Now you need to calibrate the speedometer. You need a short length of speedometer drive cable, or equivalent, and a variable speed drill. Assemble the drive cable into the drill and speedometer. Run the speedometer at exactly 60 miles per hour. You should go exactly one mile in one minute. If you went less than a mile, reduce spring tension on the speedometer needle and try again. If you went more than a mile, add tension. Repeat until the speedometer is calibrated with itself. Reinstall and smile.
The speedo is from a '49 Ford car...
