05 F350 P0446 nightmare
I have been working on this problem for a few months now, so here's the back story. I bought the truck over a year ago, it had the slow fill issue and a p0446 evap code. I replaced the evap canister, filter and purge control solenoid. Slow fill problem gone, but the evap code persisted. I checked all the wires, I have 12v at the harness and good continuity across the ground circuit. Next I tested out the FTP sensor, and not 100% sure it was good swapped it out. Still have the code. I have checked all the hoses for restrictions bends holes..etc and nothing. I also tested out the new vent solenoid to be sure it's good and tested the vapor control solenoid under the hood. I'm not sure where to go next. This is a hard code also, clear it and it returns instantly. Anyone with some advise?
Thanks in advance.
Thanks in advance.
Just got mine fixed.
My problem was a wire that had worn through just enough that when the truck was moving (just driving as usual) it would short out. It was a pain to find the wire.
My rub through wire was under the air filter plastic shroud. On my 99 ford expedition 5.4l.
But yes i understand the frustration. Hoph this helps some on your search for your problem.
Ps it frustrated me for about 2years.
musicars
11-07-2015 11:54 PM
