Should fan be spinning constantly
Do yourself a favor. Fire up the rig, open the hood, stare at that set up for a while, and try to figure out any way whatsoever that it would not turn all the time.
And try to get that race mechanic over there to help you out.
And out of curiosity, how did this come up? How did it come to be that a "race mechanic" told you that your fan shouldn't be running all the time?
The race mechanic was telling me how there is a clutch in there that releases with springs somewhere, and that I would probably want to looking into getting a new fan/fan innards, or change over to electric because it would free up something like 30HP....LOL! I literally laughed when he said that. He replied with; you think I'm kidding but I've been building cars for 40 years.... Etc etc...
I had a stock, fixed 4-blade fan on the 240 in my truck. If the engine was running, the fan was turning at the same speed as the water pump pulley.
I replaced it with a 7-blade Ford fan with a clutch. As long as the engine is cool, the fan turns at a slower rate than the water pump pulley but, it still turns. As heat from the radiator blows across the thermostatic spring in the middle of the clutch, it has more positive lockup to spin the fan closer to the speed of the water pump pulley.
