1992 F-350 Headlight Assembly Removal - Ford Truck Enthusiasts Forums
Old 02-05-2002, 02:27 PM
HeyYou HeyYou is offline
HeyYou is starting off with a positive reputation.
OK, so I think I'm pretty handy, but I've given up trying to figure out how to remove the headlight assembly on my crew cab dually. The headlight has a condensation problem and I want to take the assembly out, drain the headlight of water and then try to seal it.
What's the secret?
Old 02-05-2002, 03:46 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
It's tricky, i had to take the battery out when i changed my yellow blinkers into clear ones. There are two square cut outs in the metal for u to stick a 10mm socket in there with a 4 inch extention. I also had to move the coolant overflow/washerfluid tank, i just unhooked it and w/o removing hoses, placed it aside. That will get ur corner lights out and you hsould be able to get the headlights out after that.
Old 02-27-2002, 08:43 PM
Having performed the aforementioned Headlightectomy I return to report the proper procedure. This is for the driver's side headlight.
Loosen Washer fluid/radiator overflow reservoir and set out of the way.
From the inside of the engine compartment remove two 11 mm screws from light assembly, using a 3" extension.
Remove two Phillips head sheet metal screws from top chrome trim piece.
Remove light assembly. Remove lights from assembly and set assembly aside.
Headlight is now held by the three headlight retaining/adjustment bolts. If you possibly can without stripping them out, unscrew these retaining bolts and remove headlight. If you cannot unscrew these bolts, try to remove them by rotating the plastic locking retaining clips from the headlight by lifting the two locking portions on the reverse of each clip and then rotating the clips with needle nose pliers 1/4 turn. If you can't do that, remove the bolts any way you can (vicegrips and about 1/2 hour each will work) and then go buy new retaining bolts for $6 each at your Ford dealer. This last procedure worked for me.
Then allow the ice and snow storm to hit while your pickup sits in the driveway with one headlight missing.
Reverse the above procedures when it warms back up and the ice and snow melts.
Old 03-01-2002, 10:59 AM
CUWaldo CUWaldo is offline
CUWaldo is starting off with a positive reputation.
You forgot to mention that the 11mm nuts will be frozen on there really good, and you will in turn just unscrew the whole shaft from the turn signal light assembly, making your situation much worse, than better. The person who designed this system, along with the guy who decided that a hydraulic clutch slave cylinder should go INSIDE the transmission, should be strung up and tortured.
Old 03-01-2002, 03:15 PM
GREASYROD GREASYROD is offline
GREASYROD is starting off with a positive reputation.
Along with the guy that decided to put the 302 pcv valve on the rh valve cover under the intake where you can't even see it instead of on the wide open left side.
Old 03-01-2002, 03:58 PM
89 f150 headlight wiring Redmonkeynut 1987 - 1996 F150 & Larger F-Series Trucks 4 12-26-2014 02:57 PM
Headlight Assembly jzexcursion2001 Excursion - King of SUVs 26 04-24-2012 11:13 AM
exchanging 650 headlights tlchomeimprove Large Truck 4 06-20-2011 07:50 PM
early 97 headlight header panel eastside 1997 - 2003 F150 8 09-12-2007 09:34 PM
How to remove headlight assembly? live2hunt 1978 - 1996 Big Bronco 1 08-26-2007 08:17 PM
Tags
1992, 96, adjustment, assembly, bezel, cover, f150, f350, ford, headlamp, headlight, headlights, lense, removal, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
