Starter help needed
Starter help needed
My buddy has a 1953 f-3 truck with a Flathead V8./ The engine was just rebuilt along with a new 6 volt battery,2ga batt. cables solenoid and have tried 2 new starter.The engine will crank over ok with no plug in it but turns maybe 1/2 turn with the plugs in. With the plug out and cranking, put my finger over 1 hole and it locks up. I tested the batt and it is fully charged. Tried jumping for a second with 12V and it is a little better. Ant thoughts?I used one of the old style amp gauges that you hold against the batt cable and it reads 200-230 amps.
Joe, HarleyMSN went through something about like this a while back. Had his starter rebuilt, checked and rechecked by the rebuild shop but still not enough power to spin and start the engine. He installed an old original starter that I had layin' around and it starts like it should. I don't know if he ever resolved the original starter issue or not. Perhaps he'll weigh in on his findings.
Found it to be the solenoid. when put the batt cable straight to the batt it cranked over fine. I bought a new one from a Model A parts store and that one was defective it would start as soon as I put the cables on it with out the trigger wire. So now I will go back and get another one and see what happens.
Rusty_S
06-12-2015 06:39 PM
