STC fitting threw back plate.
Wow that sucks. Imo if the tube went far enough back too
crack the back plate our go thru it as you said. Get the branch tube. You may be able to bend it back but you wouldn't know if it has a crack until your all back together and running or attempting to run. How many miles on the truck? If your pulling branch tubes you could pop in a set of new lifters. I feel for you as an hour and a half or so job of replacing an stc fitting just turned into a lot more.
If you haven't done it, I suggest you do it. I got a feeling I'm going to need a branch tube assembly too. If I got the numbers right in my head it will be a grand in parts. It sucks because I got transferred at work to a different department and I'm not going to be able to figure out the time frame to fix this along with the other crap I got going on. I know the wife isn't too happy cause she said sell it............that didn't make it any better either,nothing like getting kicked in the nads when your down.
She said "you spend too much money on this truck...."
Knowing where she was going I said: "YOU STOP RIGHT THERE! "
Take care of your truck and get it back on the road. I'd much rather keep my $300 a month 6.0 than buy a $700+ a month 6.7 with a warranty that I can't work on and may cost me big money when it's out of warranty.
I agree, get the branch tubes as it's one of those "better safe than sorry" kind of things. Diesel Tech Ron and even Senior Master Tech recommend replacing the branch tube when the STC blows out like that.
I would say just the same that has already been said.
The lifters are a very good idea. I have a local guy here
that has a very good rep. He says that it the truck is over
200K miles if he is anywhere near the lifters they get changed.
That being said I'll toss one more at you. New style pushrods.
The thought being if we are right and they put less stress
on the linters that would be a good thing.
I'll call in a little bit. My number will now come up as unknown.
I had the ID services blocked do to a problem on this end.
Yep scammers call from a local # and when you call back they have
yours. It was Expedia or so they said this time.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
I'm still up in the air on where I'm going to do it.I don't want to tie up anyspace a my friends shop cause I can't get any time frame for days off from the job that pays the mortage. I may have to do it at home and pull the motor in the driveway cause the truck is too high. I got to think on this, or just say screw it and ship it to Anthony and write a big check. But he's the only one besides me that I want touching my truck
on
You dont pull the engine to replace the rear cover.
Pull the pump out, replace the fitting reinstall and air test it.
From there pull the trans, slide it back about a foot and replace the rear cover.
You need to be careful of the bed plate gaskit however.
Once the rear cover is replaced reassemble the top side, this is when you put the pump cover on... not before this.
Sorry to hear of your troubles Per4mance. I do not know much about that style 6.0 as mine is the '03 year. As for working on the engine in the truck, I use a motorcycle lift. I push my small roll around toolbox up there and still have room to walk around. It is the correct height flat but can be raised. Much easier on the back.
