Leaking Oil Drain Plug
So I had my oil changed at a shop. They showed me the oil plug that came out of the truck and it was stripped. They got a new one from Napa and installed it. I figured that was it. I drove the truck maybe 100 miles around town over the next few days before going to work. When I return after 3 weeks offshore I return to find a large black spot under the truck. Drive it the 5 miles home and it pours oil in the driveway. Turns out the new plug is stripped.
My question to the group is what route should i go? Replace the pan or make some type of repair?
All you really need is a "washer head" bolt of the right size/thread. And you should be able to drill it out and rethread to the next size fine-thread.
You will then need to use a PTFE washer on the bolt/plug, and everything should be good.
Your bolt needs to have a large flat head like the original plug so you have some sealing surface, and you won't need to worry about the threads leaking -- the only sealing surface is between the "washer" part of the bolt head and the pan.
Versus just drilling out and re-threading the existing pan. If I recall correctly, the nut welded inside for those threads has a bit of extra space for drilling out.
Just trying to save you some significant hassle.
