Please help with maintenance checklist for 1986 F150
Hey guys. I'm more than likely about to be buying a 1986 short wheelbase 4x4 f150. It's got a 351w with auto tranny. The truck has been sitting for a year now, but had just undergone a fresh rebuild before the owner moved out of state and left the truck behind. I'd really appreciate y'alls help coming up with a checklist of things to do before I put the truck back on the road. I know the obvious fuel pump, filter, and oil change. But what else should I do? Thank you in advance for any and all help!
Don't assume anything was done correctly. You should drain and refill the transfer case ad both differentials. However, the diff's aren't easy to drain and usually requires a suction gun.
Also lube the u-joints and slip yokes on the drive shafts as they are frequently dry. And, check the brake fluid level in the master cylinder, and change the engine oil and filter.
-fuel pump and filter changed
-drop and clean gas tank
-oil change along with oil filter
-both differentials and transfer case drained and refilled
-grease u joints and yokes
-brake inspection
-tranny flush
Sound like a pretty solid list to y'all? Also, what do you mean pack the bearing up front?
The wheel bearings on the front axle. Pull those down, inspect the bearings and re pack. Probably should do hub seals when you do the bearings. Don't get in a big hurry to buy new wheel bearings. Do a good bearing inspection once you get them cleaned up. The bearings in the front are more than likely made with better steel than what you will get from Chinese stuff the parts stores sell.
The 4x4's have more than one seal per side I believe. Maybe Gary Lewis or Ctubutis will post an exploded drawing of the parts on the D44 TTB.
Just a little over a year ago it was being driven every day. But the owner quit driving it when the transmission mount broke cause the driveshaft hits the gas tank now.
