Need a new battery
#31
#32
#33
So I am at a loss here! Didn't Apoc get a Diesel? Has he had the battery tested? Has he checked for a parasite draw?
To answer someone else's statement of manufacturers of batteries. From selling batteries and parts for oh 15 years of my life, there are now just a handful of battery manufacturers. Johnson Control and Exide are the top two manufactures. At least they where almost 20 years ago when I got out of the business. Well according to wiki they are still separate from JC.
Duralast batteries IIRC are made by Johnson Control.
Lets cut to the chase. APOC go to the local AZ and ask for a loaner battery. Have them charge your battery over night and load test and go from there.
#34
#36
If it's got a dead cell, you should be able to test it and not get a reading over about 10.5 volts. If it's sulfated, you're going to read 10.4-12.4.
A battery at 100% state of charge, and in good condition will show 12.7-13.4.
Sounds like sulfated more than anything, which depending on which "series" of battery you purchased, may or may not be covered.
Battery warranties are very vague, from any maker, and you have to read the fine print, a lot of times you're only covered if they're a couple weeks old, or suddenly puke out all the guts across the engine.
#37
Well the main problem is it's hard to start in the morning by the time I get it up today and it's fully charged and everything is fine advance is not showing that it has a dead cell but it is at AutoZone but advanced has what seems to be a much better machine to test With. He said I might have a diode going bad in my alternator but other than that he said everything was perfect.
#38
#39
#40
