rpm / torque graph for fe 390 / 360?
hio silver--
my mileage was approximately 6 when i got the truck up and running from bone stock equivalent, frankenford field queen status.
i replaced the 4.10 gears with 2.78 gears and replaced the 29" standard diameter tires with 33" MTs. Then I got the engine overhauled which gave it a tuneup and eventually a new vacuum advance. this is with dana 60 on front, dana 70 on back (not the best choice for mileage, but rugged). detroit locker on rear.
this brought the gas mileage up to 8.6.
now it is in the shop with the engine in the process of being upgraded from a 360 to a (standard truck) 390 and the intake and carb from stock to edelbrock (intake: performer).
i am guessing that the transmission is a bw t-18 (i think it is correct).
it is a 4wd.
i am trying to improve long haul freeway mileage (i know, i know).
mikes_68_f100--
hey great graphs. it seems as if the engine peaks out at 1500-2000 rpm. i am wondering if the lower end of that range might be usable for overdrive freeway cruising. the chart makes that a tempting presumption (but am i reading it right?).
also i do not know what the manifold pressure might be useful for (but i am willing to learn, especially if it affects gas mileage).
general question-- how does the curve move (if at all) when considering the fe 390?
related question-- should i get a tachometer? if so, which one? one that i saw seemed to mount with a clamp directly over the steering column. i am positively inclined towards reliability, easy field repair, and ruggedness to match the rest of my truck.
thanks to all!
it is a 4wd.
mikes_68_f100--
thanks to all!
both 360 & 390 were done with 2bl 350 cfm carbs and low 8.5:1 compression ratio
if you are having a 390 built , add in a RV cam and bump the CR to 9.5 - 10.
you will see alot more hp and tq .
TQ pulls you off the line HP drags you across the finish line , so more HP you have will keep you crusing at 60 mph but at a lower RPM so you should see better MPG
RV= recreational vehicle?
I can talk with the shop tomorrow morning with this info and i might be able to get to them in time before they start the rebuild.
tia!
edit:
ref:
https://www.ford-trucks.com/forums/6...the-390-a.html
Lunati changed their part numbers , here's the new number for the 62001
http://www.summitracing.com/parts/lu...view/make/ford
