Hi Jim, thanks for the heads up! Glad to be a part of FTE. I've already had someone help me out with an electrical problem (turned out to be simple but it baffled me). This place is great!
After visiting a Ford dealership in town I found out that factory fender flares are in fact NOT what I want. It turns out that the factory flares require you to drill into the SIDE of the body to mount them properly. So basically, if you screw up or decide not to put them on after all, your body is totally messed up and full of holes. Furthermore, it invites rust to form and I doubt it would be repairable after it rotted through and peeked over the flare.
I guess I'll stick with some aftermarket ones, although I don't want anything too outrageous. I picked up a Canadian Tire accessories catalog that has stuff from all the big-name vendors as special order. I don't think I'll order stuff from CT, just browse the book to give me an idea on what's out there. There's some nice stuff there but if anyone here has some experience in this area their advice and opinions would be much appreciated!
Thanks again!
SnubNose
