1978 - 1996 Big Bronco
Tailgate window issue
Old 08-22-2015, 08:46 PM
bbygirl778's Avatar
bbygirl778
bbygirl778 is offline
On my 78 bronco, rear window did not work unless I did it by hand, replace motor I can hear it run but window don't move on it's own although it's much easier if someone holds the switch as I move it by hand. I removed window and still motor will not move regulator on it's own. I have cleaned up and greased the regulator will no luck. Could I have a bad motor or what? Should I unbolt motor from regulator and see if the gear turns when I flip the window switch?
Old 08-22-2015, 10:30 PM
phillips91's Avatar
phillips91
phillips91 is offline
That is a pretty common problem. There are plastic internal parts in the motor and when they wear out the motor still spins but doesn't work properly. There is a place that sells a rebuild kit with metal parts or you can replace the entire unit.
Old 08-26-2015, 08:12 PM
g_k50's Avatar
g_k50
g_k50 is offline
Try to lube the weatherstriping gaskets. I use silicone on my 1990 rubber.
There is a plastic gear in the motor that has grease in it, take it apart and inspect and regrease.
Old 10-03-2015, 02:42 AM
seattle64's Avatar
seattle64
seattle64 is offline
I'm sure you fixed it by now. On my 93 bronco I ended up inspecting the gear drive attached to the top of the motor. The 3 plastic pieces inside had exceeded their useful life. I dropped 3, I think 1/4" nuts, in there place. Greased it up good and It works. Easy fix. Less than a half hour. Read about it on one of bronco forums. The guy was real sharp.
msd0912
15
04-21-2007 08:15 PM
JFH
1999 to 2016 Super Duty
03-05-2007 01:46 PM
BroncoForLife
04-03-2006 04:36 PM
89Bronco_EddieBauer
06-06-2003 03:11 PM
79GreenMonster
04-06-2002 11:34 AM
Quick Reply: Tailgate window issue
