F250 Auto Trans Upgrade - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Log In
Old 08-22-2015, 07:46 PM
antscuts antscuts is offline
antscuts is starting off with a positive reputation.
Hey are there any auto trans upgrade out there other then the standard aod
Old 08-22-2015, 07:58 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to behold
F250 should be an E4OD.
What is your end goal?
__________________
2013 Ford Taurus Limited 3.5L
2006 Ford Mustang GT 5-speed 3v 4.6L
rla2005@yahoo.com
Randy A | Central Illinois
Old 08-22-2015, 07:59 PM
DeereFord300 DeereFord300 is offline
DeereFord300 is starting off with a positive reputation.
If your sure that your truck has the AOD and not the E4OD, then you could upgrade to either the E4OD (auto) or the ZF5 (manual). Both are of relatively equal strength. The ZF5 would be easier since both it and the AOD do not require computer additions or modifications.
__________________
Mark
'86 F150 XLT Lariat LB, 300 I6 w/4-spd (original owner)
Old 08-23-2015, 01:18 PM
Your right iys a e4od sorry im looking for something better on the highway when pulling a trailer i want to stick with a automatic
Old 08-23-2015, 01:22 PM
You've got the best auto trans that came in these trucks Imo. C6 internals with OD/electronic lockout, if your looking for an extra gear, anything is poss with enough time and cash, but I would look for a newer super duty if you want a 5 or 6 spd bad enough
__________________
Mark
Old 08-23-2015, 02:00 PM
rla2005's Avatar
X2...you have the best transmission available at the time. Later versions will not fit your engine unless you go to extremes and make an adapter then figure out how the computer can control it.
__________________
rla2005@yahoo.com
Old 08-23-2015, 02:09 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Better in what way?
What engine does your truck have?
How big/heavy is the trailer?
__________________
Paul (Conan) O'Brien
2006 E250 4.6L 4R75w 4.10, 2004 Ranger 3.0L 5-sp X-cab 4.10, 1994 Ranger 3.0L 5-sp x-cab 3.45, 2004 Subaru Legacy 2.5L 5-spd
1996 Kawasaki ZX11D, 2002 Honda VFR800,
Old 08-23-2015, 03:55 PM
351w better like more torque a little more speed lower rpms at higher speeds
Old 08-23-2015, 05:37 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
A transmission is not going to help you in either situation.
For more torque you want lower gears
But for lower rims at highway speed you want higher gears
__________________
Looking for Blue 40-20-40 seats. PM me !!!
Old 08-23-2015, 06:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
If you want a lower overdrive ratio you'll need to design and build custom gears. You could buy a whole fleet of brand new trucks for much less than that would cost.
__________________
Mark
Former Ford Automatic Transmission Engineer 1988 - 2007
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Old 08-23-2015, 06:38 PM
More torque at low speed and lower engine revs at high speeds is contradictory in terms of gear changes
__________________
Mark
Old 08-23-2015, 07:30 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud of
sounds like you want a diesel more than anything.
__________________
Chip Truck: '93 F250HD XLT 4x4 1st Gen Navistar 444ci IDI Diesel w/ Bull Moose IP,Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 3.55, Dually, 9' Dump & Plow.
Log Truck: '93 F-Super Duty (F450) XLT 1st Gen Navistar 444ci IDI Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 5:13, Dually, 16' Dump & Auto Crane.
Old 08-23-2015, 07:50 PM
Conanski's Avatar
Lots of ways to get that and it gets discussed all over this site on a nearly daily basis so start reading.
a little more speed
Which means more horespower. See answer above.
OK here's the dirt. Forget about achieving 80mph at 1500rpm that is just not gonna happen, even when built up this motor should be turning about 2500rpm at that speed otherwise it will be totally under geared for towing. So no you can't have your cake and eat it too, you could get those results with a new diesel truck but those don't deliver super high fuel milage while towing either, so I don't know if it would be worth the cost for you.
__________________
Old 08-24-2015, 11:37 AM
Nothing Special's Avatar
Nothing Special Nothing Special is online now
Nothing Special has a very good reputation on FTE.Nothing Special has a very good reputation on FTE.Nothing Special has a very good reputation on FTE.Nothing Special has a very good reputation on FTE.
Couldn't a higher stall speed torque converter be a non-engine way to get more torque / power? Any time the torque converter clutch isn't locked up you'd have higher engine speed, which would likely move you up the torque and power curves. But when the TCC locked up you'd be back where you started, so at least it wouldn't make the engine run faster at higher speeds.
Of course you never get something for nothing. I'd expect more heat meaning more fuel during acceleration. And it'd make a good cooler all the more important.
__________________
Bob
'97 F-250HD 4WD Crew Cab, 460, E4OD, 4.10:1 http://www.ford-trucks.com/forums/13...sb-thread.html
'71 Bronco, 302, NV3550 5 spd, Atlas 4.3:1, 4.10:1, Detroit rear, 33" BFG AT http://www.ford-trucks.com/forums/12...ospective.html
My toys: http://www.ford-trucks.com/forums/12...-jeep-etc.html
Old 08-24-2015, 02:19 PM
Scndsin's Avatar
Scndsin Scndsin is offline
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Question please, can't say I've ever heard it addressed...
Is it possible to put a gear-vendors on an E4OD?
__________________
David- Mississippi Chapter Leader
94 F-150 XLT 5.8/E4OD SuperCab, 2WD
Join the Mississippi Chapter, HERE
What YOU say about others & HOW, speaks more about your character than I could ever achieve.
Similar Threads
292 manual to auto trans///how hard? filthy6 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 8 12-22-2014 06:51 AM
y block manual trans to auto trans conversion ? filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-12-2014 02:58 PM
69 trans pickle1280 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-14-2014 12:18 PM
1978 f100 trans swap 77DS 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-16-2014 02:53 PM
Upgrades to E150 - Third Generation, 1986 LRevell 1968-2013 Full Size Vans 0 10-20-2013 05:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
