47 1.5 ton rear end
The Green Books lists 5.14, 5.83, and 6.67 ratio options. Have you looked for a tag on the axle? Some axles have a tag with the ring and pinion tooth count numbers on it. Otherwise you get to jack up one side, spin the wheel two revolutions, and count how many times your drive shaft goes around.
47 1.5 ton rear end
A couple of thoughts. You could run a 700R4 O/D tranny instead of the turbo 400. Another option would be a rear end out of a mid '70's or so Dodge motorhome M400 chassis. The frame width is the same as your truck and it will have the same 5 on 8" wheel bolt pattern. The one I had for my '40
1 1/2 ton was a 4:56 ratio. One final thought would be an auxiliary trans. My '40 had a Watson 3 speed (low, direct, and O/D) but it still beat me up driving it around town. JMO
An axle swap is easy if thats all you want to do. But with swapping the body onto a modern frame it would definitely make it easy to get all the nice things like PS and PB.
And I think the old mad max movies definitely set me on the path to getting my hands into old trucks more than anything else. I thoroughly enjoyed the new film just because of the vehicles.
Yea I've gone that route before, putting sheet metal on a modern frame, I didn't like all the fabricating I had to do to make everything fit, with all the bolt on kits out there makes it easy to put disc brakes on the straight axel, and mount a power steering box on ang go.
1 1/2 ton front ends are completely different. But if I remember correctly mid '80's 3/4 and 1 ton disc brake assemblies can be adapted to the 1 1/2 ton front axle but now you have 8 lugs instead of the 5 on 8" pattern. IMO stay with the stock front brakes. They will be more than adequate for everyday use.
schaper
1947 and Older Ford Trucks
03-08-2009 11:17 AM
Gold Dog
01-05-2006 08:31 PM
4x4fordtrkn
08-16-2005 05:06 PM
