Swapping in ford 9in rear in my 53 f100 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
Old 08-22-2015, 04:51 PM
Pappys53's Avatar
Pappys53 Pappys53 is offline
Pappys53 is starting off with a positive reputation.
I want to get the 9in I bought in my truck. But I am not sure what u-bolts to use knowing it is larger diameter then the original one. There will be space in between the ubolts and the springs, is this ok? I have a pair of original shock plates of a 350 series truck which will work with the 3in diameter. I would like to be able to use them. The other question I have is I want to remove the three overload leafs that are on my truck. How much will this lower the rear? They are cracked so they need to be removed. Also will this affect the regular springs any? I know they really need to me replaced but do not have the money for that right now. I want to get the 9in in since it has 3:23 gears which should help my gas mileage and not make the 350 run such high rpms.(I know some of you are cringing right no chevy in a ford) It was in it when I bought the truck. I plan to replace it one of these days, but there are more crucial things that need done.
Old 08-22-2015, 05:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
I had the same situation with about 1/8" between the U-bolts and the springs, and have not had any problems. I think as long as you use a stiff spring plate (not just a flat plate like some vendors sell), it's OK to have some gap, not a lot.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
"Never attribute to malice that which is adequately explained by stupidity" -- Hanlon's Razor
Old 08-22-2015, 06:13 PM
Schuyles's Avatar
Schuyles Schuyles is offline
Schuyles is gaining momentum as a positive member of FTE.Schuyles is gaining momentum as a positive member of FTE.
Schuyler Travis
I used the shock mounts, lower plates, from a 57-60 F100. I used the ubolts that came with a mid fifty kit I bought when I bought the springs and the original top plate.
__________________
Schuyler
'65 F100 // 240/3spd/9" // power disc brake conversion
'56 F100 // 351m/c6/9" // Down and Forward springs/Sid's drop axle // Short and Smooth rear springs/extended rear hangers/adjustable front hangers
Old 08-23-2015, 03:00 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
FTE fan
underthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant futureunderthebridgejim has a brilliant future
The u bolts that came with my 9" were to short so I bought some from Napa, #650-4014 , U bolt 1/2x3 1/4x9RD, cut--20. 63 . They fit fine with some extra to cut off if I choose. FYI these u bolts had not been torqued at time of pic. Also I was told on my recent thread that the plate and bolts off an F2 will fit the 9" plus has the shock mount as part of the plate. I included a pic of the F2 plat and u bolts ,(the second pic) you mite pm 38 coup He may have access to a set???
__________________
Jimmy 1950 F-1 302/C4
Old 08-23-2015, 03:09 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
This is the way mine is mounted:
Click the image to open in full size.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 08-23-2015, 11:52 PM
FTE fan
The F2 set up that Ax and Schuyler have looks far superior to having the round U Bolts tight against the axle tubes in my opinion, much stouter.
__________________
Old 08-24-2015, 01:25 AM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
The stock bolts do actually fit the 9" axle tubes...... but its tight....
I made som modifications to the new spring perches and made the holes in the lower damper plate slightly elongated (not much at all), same thing with the plates that goes ontop of the springs and voila.
check the post in the lower half on this link and you will see how it can be done
DinnerHill SpeedShop: Rear axel (the easy way)
__________________
1956 F100 272 Y-block
Follow my restoration at: DinnerHill SpeedShop
Jimmy Carlsson
Similar Threads
RAS and Rear Leaf Springs installed! Sous 1999 - 2003 7.3L Power Stroke Diesel 14 06-02-2015 12:08 AM
Help with Factory Rear Blocks 2013 BDS Kit OneSickTruck Brakes, Steering, Suspension, Tires, & Wheels 1 11-16-2014 10:36 AM
2wd or 4wd lift kit? jason832 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-25-2014 01:20 PM
The spring swap, settled finally larz12345 Excursion - King of SUVs 4 03-07-2014 08:30 AM
1985 F150 4x4 - Rear Leaf Spring Center Pin & Update KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-19-2013 05:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
