Nothing with key in on position
Took my 1987 Ford F150 for a drive Thursday then parked it. Last night and this morning I replaced the wiper motor as I was getting power to the motor but nothing was happening with the wipers. Went to start the truck but got nothing with the key in the on position. If I turn the key all the way it turns over but once that happens and I let go it dies. My buddy said it might be the battery so I hooked my truck up to my wife's car and let it sit for about 5 minutes. Same thing. It seems like the ignition switch isn't getting power. I cannot think of anything I could have done while doing the wiper motor to cause this. Any ideas? I did not see a fuse for the ignition switch in the panel.
Received 3,090 Likes
on
what year truck??
if it is a 87-91 the ignition switch is mounted to the top of the steering column, roughly above the brake pedal.
the switch is a 2 part deal, half aluminum and half plastic.
what happens is with age the switch separates and will no longer make contact in certain positions.
remove the lower dash panels, ans loosen the 4 bolts holding the steering column to the dash . then with a flashlight look in along the top of the column. you will see rite away if the switch is bad.
on
use a dental pick to get in the notch on the **** and depress the spring clip on the wipers. not sure if the headlights uses the spring clip or if you have to depress the plunger on the switch to remove the **** and shaft.
then htat lower panel pops off. the other side has a screw under the headlight/wiper side panel. i want to say it is 8 mm head. remove that screw and the other side pops off.
remove the lower panel that covers the fuse panel.
then you can access the 4 bolts holding the steering column to the dash.
loosen the bolts and the column will drop enough for yo uto see in along the top of the column to access the switch.
unfortunately i do not have any of these trucks here to take pictures of, and all the old repair files with pictures were all lost with the last computer crash last year.
on
<p>that happens on these old dogs. you can push it in and hope for the best, put a dab of glue on the plug and switch, or use a few wire ties to hold the plug on.</p><p>i have had very good luck with the push it on and hope for the best route.</p><p>only had the plug come loose on one truck, and that was after around 5 years.</p>
dablack
01-08-2024 04:33 PM
