Question on removing air conditioner comp.
As usual everything with the van is tougher. I have a 98 E250 5.4l. Clutch is gone on the AC compressor. I have the belt off and the clutch/pulley flops(technical term)around. Before I cause myself undue stress, how do I remove the compressor. From the front it looks like everything up front will need to be removed to get it out. To go out the rear there is a motor mount in the way. Any guidance will be much appreciated.
If you are replacing just the clutch, compressor stays on. (no need to re-charge R-134)
The clutch plate is held on by 1 center screw (8mm or 5/16") ( there are shims in this hub that allow for proper gap of clutch/coil face)(need to check on new install-
approx. .020-.025 gap as I recall)
The coil is held on to compressor body by an external snap ring, after
that is removed it should pry off with screwdrivers/lever of some sort...
Keep an eye on location of electrical connection for coil and re-install in
the same location...
The clutch had so much wobble I needed to be sure that there was no damage to the compressor so I decided to remove it. It made it a much easier job to unbolt the shroud and just lift it up some. This made coming straight out the front much easier in terms of working space. Also because of everyone being out of the items needed on a Saturday morning I went with a by pass pulley because I need it on the road and until I can get the whole package of Compressor, accumulator etc.
My compressor may be ok. How can I check it for sure?
Thanks for the help.
rockauto.com prices seem to confirm my experience that a replacement compressor with clutch costs less than a replacement compressor without clutch, and a replacement compressor with clutch costs ~$50 more than just a clutch. Short answer - it's probably worth spending the difference to get a replacement compressor with clutch and not worrying if your compressor's any good.
Sixto
93 E150 Chateau 5.8 191K miles
Sixto
I'm about to replace my A/C compressor, got very lucky finding a new Motorcraft complete with new clutch for $260 shipped. After calling Ford only to find my cost "loaded" (with clutch) was just about $560 ($780 list) something a bit less costly became a bit of a goal. Pricing usually isn't my main focus so spending literally 5 minutes to save $250 seemed prudent.
I'd take this same approach as well---not so much from the money aspect but would think if the clutch or compressor were bad all on their own certainly the other isn't too far behind in potentially failing too.
I'm about to replace my A/C compressor, got very lucky finding a new Motorcraft complete with new clutch for $260 shipped. After calling Ford only to find my cost "loaded" (with clutch) was just about $560 ($780 list) something a bit less costly became a bit of a goal. Pricing usually isn't my main focus so spending literally 5 to save $250 seemed prudent.
Well that makes a ton of sense then----smart man!
I don't have any experience with A/C compressors other than Ford-supplied, mostly new unused stuff of recent manufacture, people looking to clean out inventory. Once bought a complete A/C re-fit kit included compressor, belt, tensioner, full line set and several electrical connectors---for like $200, new OEM box and all---shipped.
Look to eBay for good deals on better parts.
truckmonger1
06-10-2010 06:34 AM
sdellinger
06-24-2009 05:17 PM
jonathandennell
03-13-2007 09:52 AM
ichiwawa2001
11-02-2005 07:44 AM
