heater box
Old 08-21-2015, 03:38 PM
icehouse330's Avatar
icehouse330
icehouse330 is offline
heater box
Can anyone set me straight?
Heater box on floor = pre-1965 econoline pick up
Heater box under dash= post 1965 econoline pick up
Have I got this right?
Old 08-26-2015, 09:15 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
Yes, the under dash heater started with the US 1965 model. Canada changed models with the calendar year, so you could have a 1964 Canadian Econoline built at the end of 1964 with an under dash heater.
The under dash heater can be installed in the 1961-1964 Econolines. Some of the earlier models require the later wiper motor for clearance.
Old 09-02-2015, 04:36 PM
icehouse330
Thanks.... just bought a '61 and the box is under the dash.
either it was swapped, or the VIN tag was changed.....
I'm picking up next weekend...I'll find out then.
Old 09-02-2015, 09:07 PM
EmilBarnabas
The 1961 "door tag" should be riveted to the body rather than the door as they were on later models. The 1961 tag should be on the door post between the two hinges. If the tag is on the door, then it may have come from a different Econoline.
Check the bracket behind the right rear tail light. The VIN should be stamped on that.
Old 09-03-2015, 03:13 PM
icehouse330
I have the door tag photo, and it is supposed to be a 1961, but the photo of the interior shows a under dash mount....thanks for the help
I'll check the tail lite number
Old 09-05-2015, 07:51 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
3 different 1961/63 E100 heater pics:
Apocalyps
Australia Chapter
12-20-2014 04:15 AM
wahlturfcare
01-31-2014 09:51 PM
zoomeroo
05-07-2009 01:41 AM
mopar
07-27-2006 03:28 PM
brider
06-20-2006 02:43 PM
Quick Reply: heater box
