New to me '52 F1 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
New to me '52 F1
Old 08-21-2015, 09:59 AM
52 F1 Stocker 52 F1 Stocker is offline
52 F1 Stocker is starting off with a positive reputation.
New to me '52 F1
Click the image to open in full size.
Picked up my new shop truck a few months back and I'm loving it!
So far I've done these things to it:
New gas tank
Carb rebuild
Radiator overflow tank
E Brake cables
U joints and diff pinion seal
Brake adjust
repaired shift linkage
Corrected battery install, was reversed - now back to original 6 Volt + ground
Repaired all lights/wiring
Installed new (fiberglass) running boards
Plus a lot of smaller and cosmetic things.
I have a bed wood kit to install, a headliner to install and a lot of other stuff to do.
I love driving this old truck.
Rebuilt 215, new clutch, 3 speed column shifter.
I'm thinking of painting the front and rear fenders satin black and leaving the rest as is - mostly to repair patch work at the front fenders where they're starting to bubble and look like crap.
This is going to be a working shop truck, not a show truck so a few imperfections are ok as long as it's reliable.
Old 08-21-2015, 10:01 AM
c91x's Avatar
c91x c91x is offline
c91x has a good reputation on FTE.c91x has a good reputation on FTE.
beautiful truck..
__________________
1948 F1. DOHC 4.6 4r70w, Lexus IFS.. in progress
1966 Fairlane. Built 306 4r70w.
Clint
Old 08-21-2015, 10:20 AM
Thanks c91x!
Old 08-21-2015, 11:22 AM
AXracer's Avatar
AXracer AXracer is online now
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
Unfortunately it looks like the typical slap a coat of bondo over the rot and let the next guy deal with it "repair" was done on your front fenders. The fenders were originally 2 pieces bolted together and are (in)famous for rusting out. See my F1 fender repair tutorial for what was involved in correctly repairing a better than average fender: http://www.ford-trucks.com/forums/13...g-try-2-a.html
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 08-21-2015, 11:42 AM
AXracer-Reading your tutorial now-
More or less right- the PO welded steel patch panels over the typical rust - then bondo'd the crap out of it.
It was the first thing I noticed about the truck when I looked at it- the missing seam between upper and lower front fenders.
I am not sure what I am going to do about it long term, but one idea is to leave it patched, clean to bare metal and use fiberglass to finish...then with a flat finish it will be less noticeable for now.
This is my shop truck- I hope to keep it forever, so maybe a few years down the road I'll do it properly, and pull the cab and fenders off to do a real paint job.
The PO painted it in his yard- so there are runs and other issues as well.
I just don't want it to get worse, and want to use the truck now.
I'm pulling the rear fenders off to replace the painted welt and replacing it with new.
Old 08-21-2015, 03:56 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has much to be proud oftopmoo has much to be proud oftopmoo has much to be proud oftopmoo has much to be proud oftopmoo has much to be proud oftopmoo has much to be proud oftopmoo has much to be proud oftopmoo has much to be proud oftopmoo has much to be proud of
Mine was patched the same way and had over 1/4" of bondo right over the rust and the metal "patch". I ended up buying fiberglass fenders from Bebops glass works. They fit well, you do have to drill all holes, and no rust ever.
Hot Rod Components BeBops Glass Works
Old 08-21-2015, 06:43 PM
FortyNiner's Avatar
FortyNiner FortyNiner is online now
FortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to all
Warts and all - she's a beaut. Enjoy the journey.
__________________
19 and 49 F1 jes' like Henry II built ( 226 3 speed light duty)
1946 Tudor Deluxe - ran when parked ( 239 - stuck but promising )
DW
Old 08-23-2015, 05:02 AM
Yup- I'm thinking that might be my plan- go with fiberglass front and rear fenders and save the originals for eventual restoration when I've got the time to do a full frame off restore and a complete repaint.
That way I can use it now and ultimately do it right...
Heck - might even buy another old truck to use when I get the time to take this old girl off the road to fix!
Old 08-23-2015, 11:15 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
I wouldn't focus so much on the warts, the truck looks better than 90% of them on the road. Repairing the sheet metal to Dearborn standards can wait, DRIVE it!
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
"Never attribute to malice that which is adequately explained by stupidity" -- Hanlon's Razor
Old 08-23-2015, 01:59 PM
AXracer's Avatar
Chuck Frank
Yes, drive it, and let it tell you what it needs. Upgrade the safe operation items first if not done already: dual circuit master cylinder, new hard and soft brake lines, check behind wheel cylinder boots for fluid seepage (if you peel back the rubber boots they should be dry behind if fluid present replace the cylinder with new name brand DOT certified ones, not rebuilt or chinese clone ones, Napa carries these). Rebuild or upgrade steering components as needed (see my post on checking steering components here: http://www.ford-trucks.com/forums/13...licks-etc.html ). Add 3 point seat belts if not already so equipped. Order a free Classic Haulers catalog: www.classichaulers.com contains a lot of very useful information not just parts, and good people.
__________________
Old 08-24-2015, 04:54 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl has a very good reputation on FTE.petemcl has a very good reputation on FTE.petemcl has a very good reputation on FTE.petemcl has a very good reputation on FTE.
Your truck looks great! It looks like you have fixed the important things. I agree with Ross . . . just drive it end enjoy for now. You will come up with a list to keep you occupied this winter.
__________________
Pete
Northville, Michigan
1950 Ford F2 w/flathead V8/4-speed
2013 Jeep Grand Cherokee Overland Summit
Old 08-25-2015, 08:45 AM
Yup- I agree with Ross too!Been driving it, fixing the stuff needed as it comes up-
Test driving after carb. repair, the speedometer stopped working- broken cable.
Waiting until the winter to tackle the bigger stuff makes good sense.
Brakes have been upgraded to dual circuit with a booster, all steering components done.
I'll keep driving it until the roads around here get salted...
Old 08-25-2015, 11:45 AM
petemcl's Avatar
Still Learnin'
Quote:
Make sure that the cable is truly broken. Sometimes the cable core just slips out of the speedo head fitting particularly if the cable screw fittings are not screwed into the speedo or the trans all the way. I suppose that it could also happen if the cable assembly is not secured to the body properly too.
__________________
Pete
Old 08-25-2015, 05:04 PM
Thanks Pete,Did that- found cable broken about 3-4 inches above trans. where the biggest be bend is in the cable.
It's only 64 years old!
Old 08-25-2015, 06:51 PM
ALBUQ F-1's Avatar
postin' fool
If you look around, some vendors' cables have a wound-steel outer jacket, while others are cheapo plastic. Obviously the steel is more resistant to kinking and cracking. I used to get them at Antique Auto in TX, but they're out of business. They're around, just check for them.
__________________
Ross
Similar Threads
New Project mhu 1961 - 1966 F-100 & Larger F-Series Trucks 8 05-10-2015 04:51 AM
Is this stock?- other than the Rancho shocks Truckie256 Super Duty & Heavy Duty 13 01-03-2015 08:09 AM
1993 F350 7.3 5 speed fifty-two_f1 Vehicles for Sale 0 12-17-2014 09:48 PM
Caution Ford GT Porn chruby99 General Automotive Discussion 6 12-01-2014 05:36 AM
Roof cab lights Magnus E Excursion - King of SUVs 62 11-20-2014 04:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
