Gravity feed question
on
See this topic
https://www.ford-trucks.com/forums/1...ght=Torque+Pro
Thanks...
on
Thanks for that link Sam!
So my next question is -
If you are gravity feeding from a tank that is higher than the fuel filler on the side of the truck and you are feeding into that filler neck - does that mean that you are relying on the fuel filler cap to be a "fuel tight" seal?
I'm just imagining that fuel filler neck being full of fuel all the way to the top!
The fuel caps haven't been vented in yrs.
on
Yeah - I'm aware that the systems are sealed, but was more concerned about someone getting a fuel bath if they opened that cap while the fuel level in the auxilliary tank was above the level of the cap..
So that would be a strike against having the connction between the tanks being always open. I'll look into the solenoid solution too... See just how much that would cost me..
I spent about $40 for all the pipe and valves. The RDS adapter kit is $80 (retail)
I am on vacation as we speak, and played with the setup a little. It flows enough to catch up even towing at 70mph (I have g614, 75mph rated tires), at least thru the hills in Missouri!
Received 3,995 Likes
on
on
These are links to my Jolly Green thread concerning the install of my Aux fuel tank.........
https://www.ford-trucks.com/forums/1...l#post15107426
https://www.ford-trucks.com/forums/1...l#post15120711
https://www.ford-trucks.com/forums/1...l#post15150037
Been a while.. just a note to advise others..
I used one of the electric valves to control flow out of my RDS tank.
Last fall the darned valve stopped working.. the coil fried.. had to order another whole valve to get a replacement coil..
during this process I was looking at the duty cycle of the value..
100% duty cycle, but not continuous... what the heck is that? I thought 100 was 100?
anyhow, replaced coil and its working fine.. so, for those that have done the same, check the coil... I started blowing fuses.. every day
