F350 1989 engine swap
Received 3,088 Likes
on
it will require a whole lot of work and electronics to make it happen. the complete electrical system will have to be modified/fabricated, the dash instrument cluster will have to be modified/fabricated, engine and trans mounts will need to be modified/fabricated, and probably fuel system modification/fabrication.
on
also you dont need to modify out your dash, just hack into the v10 harness to give it pwr and grounds etc... its doable
on
You need the the v10 ecm for sure, and the 4r100e would be nice also...but people are making FI conversions all the time, its just a few elec connections needed to power up the alien harness...
