330 questions
330 questions
My 330 out of my 65 f-600 needs some help.
It is just wore out. Several rings were broken and the varnish monster came out of the fuel tank and ruined everything in the fuel system.
I have a very solid 360 core. I was planning on using the 330 crank (appears to be a steel unit) in the 360 block,rods,pistons and the 330 top end hardware. THe heads are fresh from the machine shop. I am just needing to get the short block ironed out.
Am I missing anything here? thoughts...pointers..? thanks in advance.
I have an extra PSD and e4 od but just not wanting to get that deep. I need this to haul rock before fall.
After some research the bearing diameter for 360 vs 330 are the same. I know they are slightly different but there is a reason ALL blocks are cast 352... I'm going tonight to get the 360. I am confident this will work just fine....i hope..lol
Make sure the oil pump drive hole in the block (where the distributor gear sits) is the same size. If you have a 330HD the hole in the INTAKE for the distributor is different, but if it's a 330MD, it'll be the same. But I'm not sure about the block.
Otherwise, same things. The ONLY other difference might be where the oil dipstick tube goes, but if the 360 dipstick is in the block, and the 330 dipstick is on the pan, a galley plug can be stuffed in the dipstick hole
I will be using the 330 balancer,crank,flywheel in the 360 block.
The boss for the oil pickup bracket is there but I will have to drill and tap that hole.
The 330 was MD so I will check but I bet the dist will work. If not I can come up with one. I have a pertronix for it as well .
I'm hopefully going to get the 330 the rest of the way torn down tomorrow.
I may not put the 360 on the good stand yet tho. I will be taking it to Ohio in a few weeks for a weekend power stroke thrash. We will need the good one for that!!! Lol
Well here is a fun tidbit. The old 330 was hurt very bad.the front main cap is cracked and it was walking and wore the face of the block. The main bearings 1,3,5 are ugly and the crank will need turned . The main bearings are .002 bearings so the patch job previously was serious lol. The cam has several lobes trashed and the second can bearing looks to have spinning in the block.
Basically I'm not sure how it ran as well as it did the last time.
stsavoie
04-16-2009 10:22 PM
ford fisherman
01-31-2006 01:54 PM
japot39
06-16-2004 06:05 PM
eric in tn
17
04-11-2003 01:46 AM
rwoodfin
01-20-2003 03:40 PM
