Has anyone used a circulating block heater on a 302?
Based on your profile you are in BC, so if it takes your truck 20 minutes to warm up in Northern BC honestly I think something is up with your heating system. I lived in Yellowknife for years, so way colder on average than you're ever gonna see anywhere in BC and it generally took 5-6 minutes at regular idle. If you see -50c actual in BC then it'll be damn near the coldest day in recorded history.
That being said if you are going to use a coolant heater in my experience you need a pump one. A lower rad hose unit does just that, heat only the coolant in the lower hose. Ya they're easy to install but they don't move the fluid much in real cold, convection only so your engine block is still pretty cold. Also until the thermostat opens all the warmed fluid is mostly sitting in your rad, versus putting a pump unit in up by the heater core and having actual hot fluid where you need it.
Additionally if you don't want to mess with freeze plugs for a block heater there's tons of alternatives: external bolt-on or magnetic, or the larger adhesive pad units that cover the bottom of your oil pan.
All of these options should be available at your local Lordco, Canadian Tire, Napa, Bumper to Bumper or whatever. Hell Walmart sells this stuff in Canada. Way more cold weather options here than down south.
*Edited for clarity
*Edited for clarity
The plug in is on a 15 amp breaker. I do not live in BC anymore. I only got this truck 2 months ago from southern BC so currently it has no block heater of any kind. 20 minutes may be an exaggeration but it takes too long to blow heat for my liking with any vehicle. I'm probably going to go with a circulating/pump heater from the bottom petcock to the heater return with a one way check valve preventing backflow. I'm honestly not too familiar with the cooling system but I want it hot at any rate.
I tested the coolant heater today. Shut the truck off two hours ago and plugged it in. Seems to be holding around 70 degrees farenheit. I imagine it will work better when I plug the factory heat in as well but for now it seems that the heater works pretty good. I was worried there would be air trapped in the hose as I had to go over the top of the engine from the drivers side to splice into the heater lines. It's -1 C out right now in case anyone is wondering.
MustangGT221
12-20-2004 12:05 PM
