I might have one at work . If you still need it tomorrow I'll post it
Ok cool thanks. Iv tried online but couldn't find one. I have a older mechanic friend coming tomorrow morning to check it out. Really sucks all I was tryn to do was fix a small miss fire and led to this
Sounds like you are making progress!
You can try switching solenoids on the injectors to see of the problem follows that solenoid. But your issue is likely elsewhere. This is just something you can try if you can't seem to find the problem.
Yep I'm getting very close thanks guys. So what's going on now is the front 2 injectors arnt getting power. But the ground side switches are working. And I tried jumping the power from the back 2 injectors and it killed the system. It all started with a bad connection from the idm. Now I ohms check the front 2 injectors. One was 3.2 ohms, the other was 4.7
Ok guys iv narrowed it down. The front 2 injectors are not getting power. And I have a clean connection to the idm. Bad idm ?? 1st injector was 3 ohms 2nd was 4.7 ohms. But this morning they were both 2.9 ohms
What do you mean by "front two"? The forward-most on each side, that is, 1 and 2? Or the two associated with the passenger side forward connector, that is, 1 and 3?
Oh sorry #1 cylinders injector and #3 cylinders injector. Ran off of the same power wire
Pretty sure its not the IDM . That said , you may want to look at the IDM harness .
I just did and she's good and I used my volt meter to check the wire and its good. So I'm thinking idm or an injector is making the idm shut them down. What do you think
