1966 F750 Rear Wheel Cylinder Offsets - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Log In
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 08-19-2015, 12:26 PM
Thomas66F750 Thomas66F750 is offline
Thomas66F750 is starting off with a positive reputation.
Maybe I'm working on this old truck too late in the evening and had a brain fart. I ordered all new wheel cylinders from NAPA, they list different upper and lowers for the rear but it looks like only the bore sizes are slightly different. The backing plate holes are about centered between the shoe slots for the rods, but the wheel cylinders all have an offset. When assembled (the only way they can go) this leaves one piston way out near the end of the bore and the other in about 1/3. The short side on the upper matches up with a long side on the lower, as if only one piston in each cylinder will be doing the work. That just does not look right. Anyone familiar with this and have a thought? I don't want to lift those hubs & drums on and off any more times than is absolutely necessary. I can't count on what was in there when I got the truck being the correct parts. Thanks very much.
Old 08-20-2015, 12:41 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
What size are the rear brake shoes?
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2015 F150 XLT 2WD Super Crew
Old 08-20-2015, 04:40 PM
Thanks for looking - They are 15 x 5 rear shoes. I took it apart again and measured everything to make sure that the piston that is getting pushed 3/8" deeper into the wheel cylinder was not actually in far enough to block the port, and the ports are left clear. Looking at the old cylinder bore staining I see that one piston resided near the outer end of the cylinder bore and the other was set back, I guess that is just they way it goes together. I had grabbed another Dayton hub 2-speed rear from salvage for spare parts and that Ford was probably 70s and the wheel cylinder ports were centered but have a different bolt spread.
One other thing I didn't see in my manual was the hose layout for the booster under the cab - that takes direct manifold vacuum correct? I found the vent cap that goes in the cab from another truck. I'll post a photo of this project when it stops raining.
Similar Threads
Converting FT Block to FE Setup ScallyWaggler 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-16-2015 06:21 PM
68 F-600 rear brakes HELP! JIW74 1967 - 1972 F-100 & Larger F-Series Trucks 27 02-23-2015 11:13 AM
Front wheel cylinder question mechanic58 1961 - 1966 F-100 & Larger F-Series Trucks 16 01-02-2014 10:09 PM
Starting a project with a butt whooping Marauder2004 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-26-2013 08:20 PM
9 inch brake offset - very confused patience 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 03-04-2009 02:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
