Engine Vibration/Flutter while in drive 88 F250 302cu in
1988 F250 302 4x4 5 speed
Here are my issues:
The truck engine would vibrate/flutter when driving and I thought it was the injectors and the truck needed a tune up. So I replaced all the plugs, wires, cap and rotor and timed to specs.
The engine idles perfect and smooth when I accelerate. Also I just replaced the Air Pump Check Valve that popped off the line making lots of noise thinking that might be one of the issues.
Took it for a spin and still did the same thing no matter if it’s in 4x4 High, low or 2 wheel drive.
I found out if I put the gears in neutral while driving and rev the engine it does NOT vibrate and it’s smooth.
It’s when I’m in gear while driving when the engine vibrates.
I’m thinking it might be a motor mount. IF so, How can I tell if one of the mounts are broken.
Does anyone have any ideas what is causing the vibration /flutter while in gear?
Thank you,
Runner
Here are my issues:
Thank you,
Runner
I check the motor mounts and they are intact and good.
Another thing to mention. Would anyone know what this wire plug is for where it plugs into?
From what I can remember, this was always unplugged. Maybe I"m missing something here.
Plug 1_zps7kmvidql.jpg Photo by jagrunner2602 | Photobucket
Plug 2_zpskadwg0on.jpg Photo by jagrunner2602 | Photobucket
Also still need some help with the vibrations.
robertdewater
03-04-2019 06:23 AM
runner
16
08-28-2015 04:21 PM
Rusty_S
04-15-2013 12:11 PM
