Catastrophic engine failure in western TN
on
Sorry to hear...
Just saw your post
Sorry to hear about your troubles, glad you got a ride home!
I happen to have a 12k trailer sitting in my driveway. When I first started reading your post, I quickly looked to see where you were. Way the heck down there!
Anyways, good luck getting rest and figuring out what to do for a replacement.
Then I pulled it out of the truck and dropped it in my Excursion with a T4 kit and S366. It got about 30k miles on it in the X before it got totaled and I swapped it back into the dually for the last 40k miles or so.
It hasn't run that great for some time now. Power was down and it hasn't made more than 25psi of boost forever. It idled fine and had adequate power, but just flat lined after about 2k RPM's. I was blaming the injectors and figured after 120k miles of veggie oil - I had gotten some 'bad' fuel from someone on the road somewhere along the way. Well, I swapped in a fresh set of 175/146's last week and there was no change in power at all....
A forensic investigation is in order, but I dunno when I'll be able to do it. I was planning to do a couple of veggie system installs after Riffraff in the Rockies and that was my income source for Aug/Sept bills. My TDi wagon needs a water pump, timing belt and a power steering rack - so its basically out of commission and I took the exhaust manifold off my little Daihatsu Rocky to fix the broken one on my Mom's Rocky, so its not working. My old 4Runner has been relegated to trail rig duties and isn't really highway worthy. I started finishing one of the rooms adjacent to my garage (insulation, sheetrock, etc) and all of the stuff from that space is in the space my truck needs to be in to swap engines.................
on
I just need a couple days of focused attention and my shop will be 100% again and I'll yank that sucker out in even less than the 2hr record!!!
https://www.youtube.com/watch?v=lX5y...ature=youtu.be
All the stuff on the left side of the shop in the video and the stuff behind the camera (the reason the truck is just nosed in...) is from the other room(s). It's all of the junk I have for doing veggie conversions (plumbing, wiring, etc), spare parts for my fleet and lots of PSD crap, all of my camping gear and boat stuff (PFD's, Sky Ski, skis, wakeboards, kneeboards, etc).
Ok, I better get to work again. I decided to make the rustbucket '02 TDi jetta I brought home as a project car run. It's the closest thing to running/driving in my fleet of junk. Maybe just a bad sensor...
Wow Jason sorry to hear that, but its a best worst case scenario. You blew the motor but at least you have another to swap in and you keep all those upgrades! I'm sure when the Ex got totaled it messed something up. Possibly valves leaking losing the boost or something, I'm sure it wasn't really the veggie oil that did her in.
But hey at least you'll have an even better engine now!
#29
No idea about cause of failure yet. Power and boost have been down for awhile. I suppose something could have happened in the Excursion crash. It was on it's side for 4hr and the engine did hydro lock with oil...
#30
Tennessee hasn't had a good good track record lately. I went camping down in mammoth cave about 3 weeks ago with my wife daughter and niece. As soon as I pulled into cave city I filled up, then the truck wouldn't start!!!!!! You wouldn't believe the **** that that fuel stop had in the tank!! Filled my water separator took out a sensor and possibly killed at least one injector.... Instantly
Glad you got her home. What's Cory been up too? He's never on here.
1.5 hours is what you should shoot for, takes me that long to change a hub on the old F250 and I thought that was fast lol
