4.9L Carbon inside valve cover. #6 cylinder issue or PCV?
I changed the valve cover gasket this weekend on my 94 4.9L.
Everything went well, and the top end looked pretty clean, but noticed something troubling on the number six cylinder.
The whole area inside the valve cover baffle above the #6 was lightly caked in carbon. The #6 itself has that darker color.
What am I looking at? Should I run a compression test? Or is it simply a symptom of the PCV valve being over that cylinder?
I'll pull the plugs after work to see. Should note I have no codes and no CEL. Engine runs as good as it always has
kameronth
10-15-2016 09:25 PM
cjben
04-02-2010 10:00 PM
