Injector cup bore cleaning, removal/install with pics .
No worries glad I can share. Nothing to the injectors other than new O-rings. Just can't afford them any more. Maybe a new thread on them next summer.
https://www.youtube.com/watch?v=l5bpNNBbNzs
Awesome, let the dust storm begin. I hope your doing ok with all those fires. We have a few hitting close to home as well. Can't even breath with all this smoke.
Ya, I was a little worried. But went ahead with it. I got the cups in and fuel rail cleaned out. Have a bunch of pics and will try to post them later.
Love videos! Thanks Rich. I had to go through the Banjo bolts cause I didn't have a bendy gun cleaner tool, just the rod. It worked fine.
Shop vac in the holes after cleaning helps quite a bit. Anything left in there goes to the coolant - no biggy. As for the fuel rails, I'll do better than a photo:
Found a good set of bore brushes at summit and an extension to get deep down into the bore. Worked beautifully.
I used a piece of plastic sprinkler tubing I had lying around and duct taped it to the end of the shop vac.
You really need to get a pick down in there to scrape off the old loc-tite and get it as clean as you can.
Thanks Tugly for the gun cleaning rod idea. I removed both Banjo bolts and put a gun cleaning cloth on the end, sprayed it with brake cleaner and scrubbed till clean. (bad pic) but look for the cloth at the end of the rod.
Another bad pic, but you can see the rod from the back side of the block to the front.
This pic shows the light at the end of the tunnel. It's a shot of the Banjo bolts removed on both sides.
Vacuum up, end result.
Wipe the install tool and cup clean. Push cup past the O-rings up to the lip.
Put on the green Loc-tite #620. Put it on the bottom flat portion and the top flat portion.
Install the tool, arrow pointing down toward springs. If you rent the tool from Riffraff and comes with the 2 bolts with the yellow tops, use those. DO NOT use the original injector hold down bolts. They are not long enough and as soon as you tighten it up, it will strip the first 3 or 4 threads. My mistake as the instructions said to tighten to 10 ft lbs an assumed that you use the factory injector hop down bolts. I just hand tighten them.
Next tighten the bolt all the way down to 35 ft lbs to seat the cup. loosen bolt and loosen the 2 hold down bolts, remove tool and clean off excess Loc-tite off the bore.
Injector cup installed.
Your pictures and instruction will be a helpful hand for many years to come. I hope I never have to do this job, but if I do I will certainly refer to this thread for sage advice.
One question, in the picture below you mentioned using a pick to scrape off the old loc-tite. I assume that the reason for the pick being in the hole for the injector nozzle is for picture purposes and you were not scraping down into the hole?
#29
Thank you for that.
I had to do a double take on this pic as well, but if you look real close you can see the end of the pick is actually not in the hole but goes towards the top above the hole.
#30
