The 6" channel iron from the bed fit perfectly within the frame rails to close up the rear of the frame.
Everything is cut and ready for a trial fit. No fancy tools here, just a 4 1/2" angle grinder from Harbor Freight.
Mocked up and almost ready to weld
Here we cut the bed and placed back onto the frame. I had a lot of extra angle iron and channel iron from the remaining portion of the bed to create a new rear bumper.
I hadn't ever heard of the show Roadkill Garage, so you peaked my curiosity and I looked it up on YouTube. This truck is so cool, but way above my abilities. Here is the episode I am referring to. https://www.youtube.com/watch?v=PVs_...ature=youtu.be
I was able to use some old fencing that I refused to throw out last year to complete the bed. Next up, I am thinking this beast needs a pair of bullhorn style pipes and stacks.
Before I messed with it, the wheelbase was 150something inches and is now 103" and this beast rides as stiff as it did before (this has all springs - front and rear -and no shocks). In the next few weeks, I will probably remove the helper springs in the rear, as well as, a few from the regular stack to see if it will soften the ride and have some give......on the flipside, this thing can turn on a dime now.
Wheels and Tires - I found an ad on Craigslist offering wheels and Firestone tires off an 1.5 ton International dump truck with 75% tread. The rear tires are 10r22.5 with an aggressive tread and the front two are 9r22.5 with highway tread. Not a bad investment for $275.
I found a set of wheels and Firestone tires for the beast. A local scrapped his 1.5 ton International dump truck and wanted $275 for the wheels and tires (75% tread). The rear tires have an aggressive tread and the fronts are a highway tread
neat. I am anxious to know - How did you make out reducing the size of the spring packs - did it help out with the ride? I am thinking of removing all but 2 leafs and installing air bags.
I never changed any of the spring packs. It rides pretty stiff, but as I take it out more and more, I am getting used to it. I am actually thinking of adding 5" lift blocks to the front to level it out.
