2014 4x4 feels like it is overloaded
It is supposed to be progressive. I agree, it is only a sensation like when the elevator reaches the bottom floor. Only this happens with every low spot on the highway. My neighbor has the exact same model as I do, but never hauls anything. His rear hitch is 2 inches higher than mine. I do frequently haul heavy loads, and never have less than 200 lbs plus leer topper. I guess the suspension has lost much of it's mojo.
I forgot to mention that I took it back to the dealer and took a tech for a ride. He agreed with me that it felt strange. He checked it out, and found nothing wrong. I asked for suggestions and his were similar to others here. The trucks with the lighter package were not designed to do more than occasionally carry weight.
I decided on the roadmaster system. Within 20 minutes of opening the box I was done. Wow, what a difference. The rear springs are now more progressive instead of spongy then suddenly unyielding. It now has the rake that a truck should have. Thank you all for your input.
Don't forget there are two different settings one for loaded and another for unloaded on the RAS system.
alfonso in Michigan
07-23-2020 08:50 PM
tomtoc
07-09-2007 05:09 PM
