Burnt Valve 460 - Ford Truck Enthusiasts Forums
Burnt Valve 460
Old 08-15-2015, 12:40 PM
Slocus Slocus is offline
Slocus is starting off with a positive reputation.
Burnt Valve 460
Hey all. Recently picked up a project truck. 1987 F-250. 4x4, extended cab, manual. Interior is great, body is decent.
However, it's got a burnt valve. So the question is, should another 460 go in it? Will a Windsor be underpowered? It's not going to be used for towing anything to big, maybe a small boat, perhaps a Miata.
It's got 162k on it, so if the heads are coming off, the engine is coming apart.
Old 08-16-2015, 10:02 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
Find a clean set of junkyard heads, have those rebuilt, and you can swap them out on a weeknight. As long as the P.O. Didn't beat the crap out of it and changed the oil, the bottom end should last you to 300k.
66 2wd Power steering conversion issue 66 Old Red 1961 - 1966 F-100 & Larger F-Series Trucks 9 01-24-2016 03:38 PM
351 Windsor loud tick Jagesage 1987 - 1996 F150 & Larger F-Series Trucks 20 12-25-2015 11:35 AM
1992 Ford F-250 manual build. Dan_Johnston Performance & General Engine Building 3 05-13-2015 04:13 PM
Burnt valve ? jmranchero 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 03-02-2012 09:17 PM
4.6 romeo to windsor hitechredneck 1997 - 2003 F150 2 04-12-2007 04:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
