mpg
Received 3,090 Likes
on
Damn, my old beater '83 6.9, with no overdrive, and an inefficient C6 auto trans, with farm truck gears, gets 16mpg while blowing white smoke indicating it's running rich and needs injectors or IP. Should get 20+ if it was in better tune. God knows how many hundred thousand miles are on that thing.
So in 30 years we've added a few HP, a thousand miles of wires and sensors, overdrive 5-6 speed transmissions, electric accessories, etc, and we can't even get 1 MPG more....
on
This ^^^^
Most specifically the NOx requirements. I've yet to find any decent data saying that reducing NOx emissions is important. Yet they are KILLING both our MPG and reliability, I'm almost to the point of calling it a conspiracy.
NOx is very unstable, in the atmosphere it does not last long at all. It either breaks down or becomes NO2 and harmless.
NOx is produced during high temperature high pressure combustion. Do you know how you get an engine to be efficient, with high temperature high pressure combustion. Then there's how they reduce NOx, the EGR. We can look back 50 years now and realize just how many reliability and longevity issues have been caused by or contributed to by the EGR.
If we really wanted to reduce NOx production the EGR is one of the worse ways to do it. There is a technology that's been around for longer then the EGR that increases HP, increases MPG, reduces NOx, and is cheap. Water injection, plain simple water injection. Aids in expansion increasing HP and MPG and cools combustion reducing NOx.
Yet the EGR was one of if not the first required emissions devices.
Conspiracy? Hell, this is right out in the open, and notorious.
Pollution is a political term, not a scientific one. Yeah, I like clean air and water as much as the next guy. Don't put words where they don't belong though. But it's a matter of degree. If I change the oil in my truck and dump it down the storm drain, that's a problem. But if I live in Texas and dump it next to an oil well, it won't hurt a thing. Each however is equally heinous in terms of "pollution".
What does logic have to do with it? The need for cars to use so much plastic in place of steel to save weight and squeeze out an extra mpg to meet federal regs has killed untold thousands on the alter of environmental justice!
My '03 F250 7.3L is getting 18-19 mpg's on the traffic-free roads of Maine. Can't wait to see it drop when I need 4WD when the snow arrives.
on
