tranny fluid: change or no?
Old 08-15-2015, 09:01 AM
rugermack's Avatar
rugermack
rugermack is offline
Changing ATF doesn't ruin a tranny, not ever changing it does.
Old 08-15-2015, 09:20 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
on the synthetic or regular oil debate, i have found synthetic leaks and regular does not.
case in point. my 2002 diesel. i took it in for a trans fluid change because it was close to 30kmiles. toold the shop to use regular trans fluid. .for some reason the "tech" put in synthetic, and tried charging me $275 for 19 quarts of synthetic ATF, and 75 for labor.
i went into the office and refused to pay for the ATF, because it was clearly printed on the invoice use regular ATF.
3 days later the shop paid for a wrecker to tow the truck back to the shop and replace what was left of the synthetic with regular ATF because 5 quarts leaked out of it while it sat in the driveway.
that was 2 years ago, and i have not had to add a drop of ATF in over 25,000 miles since i got it back.
Old 08-15-2015, 10:59 AM
joey2fords's Avatar
joey2fords
joey2fords is offline
while we are on the subject of auto transmission maintenance ...
the manual calls for band adjustment every 15,000 miles, while fluid changes are recommended every 60,000 miles. one can easily infer from this that band adjustment is even more critical to tranny life than fluid changes, yet i would wager that once a vehicle is out of warranty, band adjustments are a very rare occurence.
mileage-wise, my truck is certainly due for a band adjustment but i am a little reluctant to go after it because a) i have never done it before, b) it's kinda rusty down there and i am afraid of rounding off a fastener and c) the truck shifts like new.
should i subscribe to the "if-it-ain't-broke-don't-fix-it" theory or should i get under there and perform the recommended service ?
Old 08-15-2015, 03:25 PM
tjc transport
i ain't rite
i have never done band adjustments, just fluid and filter change every 30-35k miles.
Old 08-15-2015, 06:49 PM
Briansshop's Avatar
Briansshop
Briansshop is offline
Glad you chimed in Mark. Myth dispelled.
Old 08-15-2015, 07:10 PM
DeathRangerofDeath's Avatar
DeathRangerofDeath
DeathRangerofDeath is offline
Originally Posted by twigsV10
How many of these high mile transmissions had very old oil in them before changing the oil? I would almost bet money that they all had very dirty and burned oil when they were changed..... And that if the oil had been changed when it was needed rather than at a high mileage situation they would've lived considerably longer.
Clean oil won't damage a transmission but it also can't cover up damage done from lack of maintenance.
Isn't that exactly the point being made?
That's the point I was trying to make, anyways.
As far as second hand, yea, yea.. second hand. I've never actually had an automatic fail on me. I've built a few for projects, and I've built a couple from cores, but the only transmission I've ever had fail personally was a M5OD in a 93 Ranger 4.0 (the death ranger from my user name). It failed from not knowing about the shift rail plugs failing. That also happens to be the only time I've ever paid someone else to do the work for me.
My friends constantly had transmission failures, though.
Old 08-15-2015, 11:40 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
I'm thinking we're on different pages on what point we're trying to make, The basic point I was getting at was new oil won't damage the transmission and continuing to use old oil will only shorten the life of the transmission. The part I think we do agree on his new oil won't fix a damaged transmission.
Old 08-16-2015, 10:07 AM
cjben's Avatar
cjben
cjben is offline
How many quarts does the E4OD take including draining the torque converter?
Old 08-16-2015, 11:34 AM
tjc transport
i ain't rite
not positive, but probably somewhere around 16 quarts.
Old 08-16-2015, 04:41 PM
stuman's Avatar
stuman
stuman is offline
If it smells burnt, and you don't fix what made it smell burnt, new fluid won't fix it for long. I actually had an old Honda Goldwing that I let get too hot. After that, I had to run Mobil-1 Blue Cap (a No no for wet clutches...supposed to use black cap). If I didn't run the blue cap, the clutch wouldn't let go. Still have the bike, but no carbs...project. Maybe one of these days.
Old 08-17-2015, 12:17 AM
twigsV10's Avatar
twigsV10
twigsV10 is offline
My 94 F150 used 14 quarts but an extra quart or two isn't a bad thing to have on hand.
Old 08-17-2015, 08:27 PM
cjben's Avatar
cjben
cjben is offline
is the tranny pan gasket reusable?
  #28
Old 08-17-2015, 08:37 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
yes if rubber.no if cork.
  #29
Old 08-18-2015, 09:24 AM
cjben's Avatar
cjben
cjben is offline
Well,guess I'll buy one to be safe,can't really tell looking from under the truck.
weldboy
08-11-2007 03:24 PM
Fishallot
1978 - 1996 Big Bronco
16
10-13-2005 10:39 PM
bassguy31
09-09-2004 01:14 PM
fordmudrunner2020
04-27-2003 11:38 PM
dcrewchief
08-22-2002 12:43 PM
Quick Reply: tranny fluid: change or no?
