Opinion on trans fluid condition
on
According to a good friend (now passed on) who spent 40 years as a petrochemical engineer for Ashland Refineries - Oils actually never wear out, but the additives do and the oil can become contaminated...
Not sure why people are against giving it a fresh change.. I've never heard of any negative consequences from regular service intervals in either engines or transmissions.
I wonder if Blackstone Labs does oil analysis on ATF?
Received 1,446 Likes
on
Oil actually can wear out and that's called "oxidation". Having said that the LV oil that's in our tranny's is a synthetic oil and is much more resistance to oxidation and can last longer.
There's nothing wrong with changing the oil early. It's a balance of proper care and your wallet. Your choice!
on
I sit corrected and will have a talk with my buddy Skip when I get to heaven....
Still I think the greater problem with oils is contamination and dilution.
I am also perplexed by some manufacturers now making their transmissions totally sealed and non serviceable - even to the point of not providing a means to check fluid levels..
I agree completely about contaminants and dilution.
#29
#30
On the other hand, I don't believe in changing fluids prematurely either. The mfg recommended trans fluid change is @ 150K miles. Changing the trans fluid at say 50K miles would be like changing the motor oil every 2K miles. In other words, you're changing the trans fluid/motor oil after approximately 1/3 it's expected useful life. Keep in mind that the OP had less than 25K miles on his truck.........
Would it hurt anything to change it 'early'? I'm thinking only your wallet would complain.
