Our new 78 Bronco! - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Log In
1978 - 1996 Big Bronco SPONSORED BY:
Our new 78 Bronco!
Old 08-13-2015, 03:15 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to all
Our new 78 Bronco!
Been looking for a while... some were gone to fast, others,,, well, there is is a reason they weren't! 351M, NP435, NP205, 3.50's in axles,,, the 4 speed was what I was really wanting in it also!
Click the image to open in full size.
Old 08-13-2015, 04:16 PM
Toyman's Avatar
Toyman Toyman is offline
Beer reduction specialist
Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.
toyman
Nice solid looking Bronco. Very nice find!!
__________________
Rich
2005 F250 Superduty crew cab, 6.0L, 4" turbo back, XPD egr delete,AFE stage 2, HPOP, SCT tuner, scan gauge II, blue spring, zoo-dad mod, FICM, Sinister coolant filter.
1979 Bronco, 520 stroker, full roller, trick flow heads, reverse manual c-6, maddog fenderwell headers, 3 row aluminum radiator, derale trans cooler, Scat racing seats.
Old 08-13-2015, 05:18 PM
VIN decode anyone?!
Old 08-14-2015, 12:53 AM
ZombieSlayer's Avatar
ZombieSlayer ZombieSlayer is offline
ZombieSlayer is gaining momentum as a positive member of FTE.ZombieSlayer is gaining momentum as a positive member of FTE.
U15 = 4WD Bronco
H = 351M
L = Michigan Truck
CA8800 = Serial number
__________________
Proud owner of a 1995 Bronco XLT, auto trans, 5.8L engine. 95% original.
Old 08-14-2015, 03:44 AM
Zip Zip is offline
Lost
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
Very nice.
Old 08-14-2015, 10:00 PM
Thanks All! Hoping to start going thru it soon, engine, brakes, interior,,, carpet out, rubber or roll-on to replace it. It does start, PO took fuel tank out for some reason, hooked up fuel line to jug, primed carb, runs, needs obvious carb rebuild and vacuum leaks fixed, but all in time, hopefully before hunting season
Where would I find color and axle info?
__________________
SEMPER FI
02/Ex/4x/7.3/Limited
02/F350/CC/4x/7.3/Lariat/DRW
77/F150/SB/4x/NP435
66/F100/240/T18
63/F250/Flatbed/4x4/T-18
Old 08-15-2015, 03:19 AM
H2K = 3.50 without limited slip with power steering
Trans code A = NP435 4 spd
Color BV = B - dark jade metallic and V - silver metallic (TuTone). Best guess here as I can't find the code together (ie BV) but only as separate codes (B) and (v) and it looks to match the colors of your pics
Body Code FR1 = Is one of the Ranger XLT packages just not sure which one (obviously a XLT Ranger pkg )
DSO 72 = San Jose (where it was ordered)
__________________
Old 08-15-2015, 12:28 PM
Thanks! And it has dual front shocks and sway bars front and rear.
__________________
SEMPER FI
77/F150/SB/4x/NP435
66/F100/240/T18
Old 08-15-2015, 04:16 PM
Beechkid Beechkid is offline
Beechkid is a splendid one to beholdBeechkid is a splendid one to beholdBeechkid is a splendid one to beholdBeechkid is a splendid one to beholdBeechkid is a splendid one to beholdBeechkid is a splendid one to beholdBeechkid is a splendid one to behold
That's definitely a very clean and great foundation to start with!!!!!!!!!!!!
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Old 08-17-2015, 08:01 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
Nice rig, congrats on the clean slate to start your adventure.
__________________
2001 Excursion V10 4x4 Auto 156,000 miles 285/75/16 BFG AT's, stock rims
2nd trans cooler and spin on filter, converted to electric fan (increased MPG by 1.1mpg towing) Trans temp gauge, Volt gauge, and Vacuum gauge mounted in 3 gauge driver pillar pod, Custom Safari Rack, Full size spare on the rack, Mag light at driver door, LED interior lights.
1978 Bronco 460, NP435, BW1345, Dana 44HD/ Dana 60, 40's "project"
Old 08-18-2015, 07:51 AM
scott79's Avatar
scott79 scott79 is offline
scott79 has a good reputation on FTE.scott79 has a good reputation on FTE.
Nice score, that looks very solid AND a NP435 4-speed will serve you well...maybe it's just the pics BUT I like the patina look!!
__________________
YESTERDAY WAS ABOUT HONOR, TODAY IS ABOUT JUSTICE
Old 08-18-2015, 08:26 AM
mrdanielcruz mrdanielcruz is offline
mrdanielcruz is starting off with a positive reputation.
Nice truck!
Old 08-20-2015, 11:32 PM
Thanks guys, I have really come to love the "patina" on my trucks, just so much easier to care for,,, I do nothing to it! It really started with Mater my 63, and Shrek my 66, and well Woody my 79,,, Got to get rear brakes and bearings done on my 77 F250 4x4, Maximus, so he's ready for wood cutting and hunting, THEN I will pull the Hulk in (not sure if that is final name yet,,,) and start going thru him,,,
__________________
SEMPER FI
77/F150/SB/4x/NP435
66/F100/240/T18
Old 08-21-2015, 03:14 AM
Quote:
Hmmm sounds like you're too busy for the Hulk. How about I take him off of your hands to free up some time
The more I look at your Bronco the more I fall in love with the paint scheme. When I get my 78/79 that's how I'll paint it.
Mind sharing how much you spent to acquire it?
__________________
Old 08-21-2015, 02:49 PM
Hahaha....NOT! 8 trucks and counting,,, dang, how'd that happen? I DO have a 79 Scab 4x4, D60's for sale now that I brought the Bronco home
I paid 3k for it,,, it had what I wanted,,, 4 speed, bench seat, and AC. Now I'll dump another 2k into it probably,,, but then it will be comfy and dependable!
Similar Threads
1966 F100 Patina Finish Inline66 1961 - 1966 F-100 & Larger F-Series Trucks 14 09-01-2015 04:54 PM
remote start? joelsutter Excursion - King of SUVs 11 08-17-2015 06:17 AM
Steering connection problems Chad McClain 1961 - 1966 F-100 & Larger F-Series Trucks 4 08-12-2015 02:31 PM
Flathead V-8 good working condition 50Fiona Ford Truck Parts for Sale 0 08-25-2014 06:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
