Injector rebuild?
Injector rebuild?
I am making oil in my 97 truck. This and the fact I have a black fuel filter leads me to believe I have injector issues. Would it be worth it to send all 8 out and convert them to stage 1s? I'm about to be gone for 6 weeks so I can afford to have her down for a while.
Also, where should they be sent to be rebuilt? There has been a guy that several people have used I just can't remember who he is.
Cost involved? I think these are originals with 115k-ish on them
My engine is sitting on the shop floor with out its injectors, I put the valve covers back on and tighten a few of the valve cover bolts finger tight to help keep out debris.
So what would be the drawback of going to stage 1s vs stock? I currently have a 6637 filter, and plan on transmission cooler, gauges, full exhaust with bellowed downpipe, and later a chip.
I know stage 2s can cause high EGTs... will stage 1s do the same but not as bad?
Will I have to add an intercooler to the list if I choose to upgrade the injectors?
Its a slippery slope lol
Next thing you will need hpop ,efuel,s-series turbo. Etc.
Stage ones and an ic can be run but you will have to watch egts .
Not many combos, for only a few exceptions, can just be floored and not consider watching the egts .
Its just the nature of modding.
I can tow great with egt in check but i have to be in the turbos operating range.. And im not running ones or twos.
Its all about the total package NOT one singular part...slippery slope i tell you.
I think personally ones will be great for you!
Ok so I just pulled my injectors to send to Jim at rosewood. While I was pulling everything apart, I noticed some things that worried me. First, there was oil in the intake just in front of the turbo.. See picture.
Also, one of the injectors was significantly discolored... Was this what was causing my blue smoke?
Thanks everyone for your help!
lgreen
17
10-12-2007 07:33 AM
