Will any 302 engine line up with a manual trans for a 79 f150 ranger. 2wd? I'm sure there is a link but I'm not finding an exact answer I'm looking for
If the 3 speed was from an inline 6 or 302 equipped truck (small block bolt pattern) then yes, it will physically bolt up. As was said before, there is the issue with z-bar, but there is a company that sells a bracket that bolts to the back is the bellhouse. It's a simple bracket to make if you have a welder. If you use a late model 302, you have to use the proper balancer (50 ounce imbalance) and flywheel since the early engines used a 28 ounce imbalance.
What is in the truck now?
