cam shaft positioning sensor
Hey everybody just got back from the outer banks on the beach for a week towed a 21' car hauler with 4 hogs and all kind of stuff. The ex did great except at the end of the trip it gave me a hard time starting a couple times. Code comes up cam shaft positioning sensor. truck is a 2005 6l. Hans anyone replaced this sensor. Thanks for the help.
ok Got this done last night. Air filter assembly comes off you can reach down and get your hand barely in behind power steering pump and disconnect the wire clip. Then from under the truck you have to have a light cause you cannot see the sensor and bolt. There is just enough room to get a 1/4" drive ratchet with long 6" extension 8mm socket some how in there between radiator hose and everything else. I was only able to get it loose then had to go from above and remove the bolt. you cannot see anything. Then somehow removed the sensor oiled the orings on new sensor and somehow got it in from above hand tightened the bolt and from under tightened it with the ratchet. Cleared codes drove it around got her hot and shut it off started back up no problems several times. No cam shaft code. Was a pain to get too but not difficult. Sorry no pictures.
Ohhhhh, I see! Just another superfluous post with a buncha words but no pics to prove anything actually happened!!
Glad you got her done. Feels good not paying a ton of cash to the dealership to do something you were able to figure out with the help of others, aint it?
I know it always gives me warm fuzzies!
Stewart
Stewart
Stewart there was absolutely no way to take a picture. You could not see the stupid thing unless you held a flashlight and pointed up there. only one hand fit to get the ratchet in there. Maybe on a lift it would have been easier but doubt it. You still had to remove the bolt from above and the sensor. It did feel good not paying the extra loot for that!!
