1974 F100 Build Thread IFS, IRS, 5.0 EFI, AOD
I've been on the forum awhile but have finally decided to start posting pictures of my latest build. I'm starting with a 1974 F100 Ranger XLT short bed, automatic transmission, with a 302. Plans are to repair all the rust, paint the frame and truck, install a Crown Vic front suspension, install a Thunderbird IRS rear suspension/differential, and install a EFI 5.0 with automatic overdrive transmission.
IRS Installed
Removed the rear axle, leaf springs and associated hardware. I purchased the IRS installation kit from team321.com. I have to say that Dave from team321 is very knowledgeable and answered all my questions. The IRS kit took a little longer to install than expected but we measured several times before cutting and welding. We didn't want to mess this up.
Found a sweet deal on some 2014 mustang wheels and tires. Put it on the ground to see what my new stance was going to look like.
1989-1997 Thunderbirds. I used one out of a 1996. If you are planning on doing the swap some of the Thunderbirds did not come with disc brakes. You can also use an IRS out of 1993-1998 Lincoln Mark VIII. I didn't go that route because they use air bags and I wanted to use shocks.
Body Work Begins
We have started some of the body work on the bed which is where the majority of the rust is located. Both of the rear lower sections will have to be replaced. The bed floor isn't in great shape either but I think we can patch it. PO screwed a piece of plywood to the floor of the bed which is the cause of the majority of the rust. There are a couple other spots we will have to create patch panels for. I'm also removing the badges, lower moldings, and stake holes.
