Ruff idle on startup
When it idles rough does the RPM fluctuate between normal and lower? You said it 'stalls out' does that mean its dying and you have to restart or engine misfire and its stumbling? I'm not an expert but thought a little clarification might help the forum members that are. Welcome to FTE, lot's of good folks on here.
Looks more like a sticking IAC (Idle Air Control) solenoid. A rolling idle can also be caused by a faulty TPS (Throttle Position Sensor) or vacuum leak(s). Could be a combination of all of the above. Process of elimination.
The IAC can be taken apart and cleaned, but many times this is only a short term fix. For reference: IAC/IAB
earlschieb
10-31-2004 09:51 AM
txmoores
1978 - 1996 Big Bronco
10-22-2003 09:37 AM
txmoores
10-21-2003 05:26 PM
