So it starts: 1950 f1 4.6 dohc/t56 build
I used the Canton relocation adapter
http://www.summitracing.com/parts/ctr-22-929/overview/
That is the whole kit which is pretty nice but I built mine for a lot less.
I used -10AN/JIC fittings. 4 NPT to AN adapters, 2 strait AN hose ends 2 90 degree AN hose ends, perma-cool filter mount with an FL-1A Motorcraft filter. Stock 4.6L filters have a 22mm thread and the FL-1A filters (used on the 302s/5.0s) are a much smaller thread size. I ran my hoses strait from the oil filter adapter past the radiator support. I mounted the oil filter on its side in front of the radiator
How does the subframe graft look? If it's structurally sound and tracks straight, I would leave it. I have a late 70's Camaro subframe on my F1 that I've driven for 9 years. It handles fantastic!
On mine, the P.O. Did a pretty crude job of the frame splice, but it was so overbuilt that it would never fail. I'm in the process of cleaning up the graft, to make it more ascetically pleasing to me.
Like Dave said, there are lots of suspension upgrades available for it, if you want.
For $150, I'd be tempted to grab that other frame, too. Especially if he has a title for it.
BTW, do you have a clear title for your project truck?
Good luck, and have fun!
Yes, a frame is only as good as it's title. The number stamped on the frame is the legal identifier. If you swap the rest of your parts onto the new frame the entire truck becomes whatever that frame's number says it is. Each state is different, but almost all are cracking down on matching paperwork. Note the CV front IFS is way too wide for the F1 frame and narrowing it is expensive IF you can even find someone willing to do it, and questionable as to how it will affect the geometry. There are a couple people attempting it on here but AFAIK no one has actually completed one and road tested it.
In my dictionary "I want to make it all Ford" translates to "I have way deep pockets and looking for ways to spend it". To each their own.
Are you planning on using bucket seats? The T56 shifter will be under the seat otherwise.
We are currently putting a 2007 Mustang GT 4.6 3V and 3650 5 speed in my friend Gary's F1. I have a T56 in my 56 panel.
