How much lift does it take to properly fit 35" tires on a 2005+ Super Duty? I want to fit larger tires on one, but I don't want to raise the ride height too much, and I've always preferred the look of large tires with less lift.
If anyone's running a setup like this, how do you like it? Anyone have pictures of it?
Depending on what your rim backspacing is it could be nothing, it could be just the lugs for the side wall of a tire a full lock. Your wheel wells will clear 35" stock easily. Spacers would help give you that wide, low, full look your looking for
Ive seen guys with 99-03 SD's with 315/75/16s and only leveling kits with very little to no rub. That said wider rims or spacers are helpful. I have aftermarket rims on my truck and will be getting those tires along w a leveling kit.
