Low HPOP oil. Hard start/no start. Questions!
Old 08-07-2015, 01:08 PM
JT250's Avatar
JT250
JT250 is offline
Over the past several weeks I have developed a hard start situation that turned in to a no start situation today. Before hooking up AE I looked in the HPOP and there was no oil. What causes the oil to train out of the HPOP? It is a T500
Old 08-07-2015, 02:52 PM
cookie88's Avatar
cookie88
cookie88 is offline
#3 in this pic. Some people call it an anti drain back valve. Ford calls it a quick fill valve. In either case if the check ball becomes damaged or corroded or debris gets in it, it will allow the HPO reservoir to drain when the engine is static.
Old 08-07-2015, 03:37 PM
JT250's Avatar
JT250
JT250 is offline
So I guess I need to contact Terminator about it.
Old 08-07-2015, 04:41 PM
JT250's Avatar
JT250
JT250 is offline
Joey at TE says its not the hpop. He says there is nothing to keep the oil on the reservoir. I am confused!!
Old 08-07-2015, 04:52 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
You have a leak somewhere. Most likely an injector o-ring.
Old 08-07-2015, 05:03 PM
JT250's Avatar
JT250
JT250 is offline
Well that's what he said. Sucks
Old 08-07-2015, 06:21 PM
cookie88's Avatar
cookie88
cookie88 is offline
No. The valve is not part of the HPOP. Look down behind the reservoir toward the drivers side. You should be able to see the plug. If I remember correctly it's a 3/8" square drive plug and it is accessible without removing the HPOP.
Not saying it's not an injector o-ring. It definitely could be. The book also suggests a weak LPOP as a possible culprit.
Is the HPOP reservoir draining overnight, or is the hard/no start every time?
Old 08-07-2015, 07:07 PM
JT250's Avatar
JT250
JT250 is offline
It is not every time. Only if it sits for an extended period of time.
Old 08-08-2015, 12:16 AM
cookie88's Avatar
cookie88
cookie88 is offline
I don't remember where I put the part number, but there is a a replacement check ball and spring kit.
Your symptoms are by far the most commonly described for a bad anti drain back valve.
It could still be an injector o-ring, but if the lower one leaks it's into the fuel rail which I would think would cause a smokey start, and the upper would leak back to the pan out the top. I don't know, but I think gravity should prevent that.
Old 08-08-2015, 10:19 PM
JT250's Avatar
JT250
JT250 is offline
I replaced that in the stock HPOP before buying the T500. I wonder why Joey doesn't agree with that?
Old 08-09-2015, 03:14 PM
cookie88's Avatar
cookie88
cookie88 is offline
I think we are still not on the same page. I'm taking about the check valve in the block. Not in the pump.
I think that all the aftermarket pumps delete the in pump valve. I also think Joey is just trying to assure you that his pump is not the problem. I agree with that.
Old 08-10-2015, 07:58 AM
JT250's Avatar
JT250
JT250 is offline
Ok you beat it into my thick skull. I am with you now. I probably won't get to look into this until Wednesday. Thanks!
Old 08-10-2015, 04:58 PM
JT250's Avatar
JT250
JT250 is offline
Here are the part numbers found on a different forum which I am not a member of. I have not dug into it yet but figured I would post this while I remembered. My local Ford parts guy had never heard of it and couldnt find it on any diagram.
Old 08-14-2015, 09:41 PM
JT250's Avatar
JT250
JT250 is offline
So I took the check valve plug off. There was no oil under the plug. I read that if there is no oil in there then that is the source of the leak. Makes sense ....the check ball should keep the oil in. So I replaced yah ball an spring. I did not replace the seat because I do no know how to get it out. However that did not solve my problem. I am loosing all my oil in 8 hours.. anybody have any ideas? Injector orings would have to be really bad to drain that much oil that fast. And I would notice it somewhere right?
I am stumped!
Old 08-16-2015, 12:15 AM
cookie88's Avatar
cookie88
cookie88 is offline
Remove the HPO lines from the heads and tie them up higher than reservoir level. Then fill the reservoir and let it sit overnight. If the reservoir still drains you have eliminated the injectors as a possibility.
Has the HPOP or the reservoir cover been removed lately. I have read where either one of those gaskets can allow the reservoir to drain if they're damaged.
Quick Reply: Low HPOP oil. Hard start/no start. Questions!
