Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
'92 F150 4X4 tire size?
Old 10-13-2001, 04:43 PM
mikes66's Avatar
mikes66
mikes66 is offline
I have a '92 Nite (4x4) and am considering getting some bigger tires under it for the upcomeing winter. It's running on 31X10.5 15's right now and stock 15X7 rims. If i step up to a 15X8 rim can i get 32x12R15's under this truck without rubbing? I work for a local tire manufacturer so getting rims and tires in no problem. I just need to figure out what i can use on my stock truck. Deffinately want a wider tire but if i can also pick up an 1" or 2" clearance while i'm at it then i will.
Thanks for the help.
Mike
http://www.geocities.com/fourby4nite/1.html
Buy AMERICAN
FORD #1
Old 10-13-2001, 10:19 PM
bktoney's Avatar
bktoney
bktoney is offline
I have a '96 F150 - same body style as yours. I am presently running 32x11.50s on factory 15x7 wheels and they do not rub. In order to go to a 33x12.50, you have to go to a 15x8 wheel and a minimal lift kit (ie. 2"), or trim the front fenders. Hope this helps.
Old 10-14-2001, 01:19 PM
mikes66's Avatar
mikes66
mikes66 is offline
yep, that's what i was looking for, now i can go ahead and get some prices tommorrow at work. I'm all for lifting my truck and going to a 15X8 but the wife is pretty much dead set against it, she struggles as it is getting in and out, which i guess makes sense, she's on the short side and used to getting in and out of her '94 Probe. I figure i should be able to sneak the 32's on without her noticing.
Buy AMERICAN
FORD #1
Old 11-06-2001, 02:07 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
yes the 32s will fit on the stock rims w/o a problem. The only problem is the brakes. My buddy has a 94 bronco with 32 mud terrains and it is alil hard to come to a stop. But you will have no problems with clearance. You don't have to get new rims either. If i am not mistaken, I believe they are 15X7.5 but i could be wrong. Take a wheel off and it should be stamped on the inside of the wheel. But take a rear off to avoid the brake dust mess.
95 F-150 2wd Extended Cab Eddie Bauer
4" Superlift Suspension
Gibson Cat-back on 300ci I-6
Ram Air-MSD Ignition-32 BFGs
Old 11-07-2001, 12:36 AM
woodbutcher's Avatar
woodbutcher
woodbutcher is offline
Remember to look at more than just tire size, I have 31x10.50s with a real wide heavy lugged shoulder on a 92 flareside 4wd, and they rub (rumble) at full lock on the radius arms.
Old 11-08-2001, 03:51 PM
beratte's Avatar
beratte
beratte is offline
If you have the E4OD don't forget to reprogram the speedometer when you change tire sizes. It will make a big difference in shift points.
Best of luck, Ben
1995 Bronco XLT, 302, E4OD, 31" BFG AT's
Old 02-04-2002, 01:13 AM
RBrendel's Avatar
RBrendel
RBrendel is offline
Post '92 F150 4X4 tire size?
i have a 94 f150 xlt extended cab 4x2 maroon, it has the factory tires and rims 15 x 7 i think and im debating to either put 32x11.5's or 33x10.5's i dont know which way to approach it shorter and wider or taller and skinnier ( i am going to put bf goodrich all terrains)i want to be taller but i dont want it to look bad, i only have 2 wheel drive so id ont want to go all heavy duty and put new rims, i think the 33x10.5's will fit and im not sure how big of a body lift to get, i need to raise thre front because it looks bad so low, but if anyone has ever seen this truck with either tires tell me which looks better.
Old 02-18-2002, 06:46 PM
gamehunter's Avatar
gamehunter
gamehunter is offline
Old 03-02-2002, 09:24 PM
Hotweilz's Avatar
Hotweilz
Hotweilz is offline
Hi,, I"ve got a 92 4x4,, 33x12.5,, I went to 10" rims,, they work perfect with a 2" lift. Don't get the "leveling kit" that advertises 2",, it doesn't.
The stock wheels aren't wide enough for 12.5's.
Old 03-02-2002, 09:31 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
I have a friend with a 1990 F-150 4x4 with 33x12.50's on the same rims I have on my F-150. I was thinking they were too wide too, however that must not be the case.
'93 F-150 loaded and modified!
Check my Gallery
Old 03-03-2002, 08:22 AM
Bronco330022's Avatar
Bronco330022
Bronco330022 is offline
Hey
I have a 94 bronco
I just put 31s on it
How do i recalibrate the speedo??
Thanks
Scotty
Old 03-03-2002, 02:52 PM
beratte's Avatar
beratte
beratte is offline
go the tech articles page and there's an article on how to do it.
skips69
08-02-2015 06:13 PM
mike L
09-18-2013 07:16 AM
mikes66
Nite, Nascar & Other Limited Edition Ford Trucks
48
09-18-2012 04:51 PM
NiteEditionF150
24
05-21-2012 08:38 PM
low92flareside
07-14-2004 08:07 AM
Quick Reply: '92 F150 4X4 tire size?
