google images of fabricated valve covers
Bouncing around the internet, I saw a thread about valve covers that had sufficient clearance for various makes of roller rockers in Ford Big Sixes. One guy called Clifford and quickly bought their second-to-last remaining valve cover.
It occurred to me that a valve cover would be an interesting welding fabrication project, so I googled "welded valve covers," then Images, and found some examples. I think you'd need access to a milling machine after you weld (and leak-test) the part, and maybe get it stress-relieved. But for some guys, this could be an answer to the problem.
I might try it myself, but I don't know that I'd show photos. I have most of the gear (and can quickly get what's missing) to do aluminum TIG welding, but I haven't done any of that in years, and would be embarrassed to post the results! But if you want to see some glorious TIG work, google welder John Marcella and look at the intake manifolds he builds.
I suppose you could get away with that, avoiding warping by bolting the valve cover to a head, and doing the cutting and welding as high up on the cover as you can. Tack the extension with tackwelds every inch apart and applied sequentially on opposite sides, and then weld between the tacks in the same manner, and back-stepping. Still, not easy to get nice results on very thin steel stampings. But if it doesn't have to look real good, it could be fine.
Couldn't you machine either some aluminum or steel that exactly matched the profile of the sealing surface on the head and make it tall enough to work as a spacer?
Someone with a CNC milling machine should be able to make one. Could experiment to see if it would be best to use aluminum, steel, or even phenolic resin. Seal it using two valve cover gaskets one above and one below. It would work much the same as a throttle body spacer.
NavyMIDN08
01-31-2010 02:50 PM
Jrock909
03-04-2007 09:22 AM
Jrock909
01-21-2007 10:37 AM
stegmst
07-19-2005 12:03 AM
Crazy Canuck
02-21-2004 08:40 PM
