Fuel gauge
My buddy who races a foxbody still runs FI and has a gauge on the cowl. I guess you need the adapter to screw into the schrader valve for 1/8" pipe fitting.
Something like this:
http://www.summitracing.com/parts/atm-3280
or better yet:
http://www.shop.speedunlimited.com/p...e-fitting.aspx
or better yet:
3/8" npt? Wow, that seems pretty large. What brand?
I've seen some that come with an adapter for the 1/8" male to go up to 3/8" to fit larger holes.
Here is one from Autometer that is 1/8" npt.
Auto Meter 2229, Auto Meter Replacement Senders & Sensors | Auto Meter
Has anyone ever removed the schrader valve from the fuel line?
The automata adapter 3280 shows it is 1/6" NPT to 1/8" NPT but the Schrader valve has no hex to grab with a wrench. I don't want to go twisting it off with a pair of Vise grips if it is not designed to be removed and brake the fuel rail
My grandfathers was leaking, I replaced the whole valve. That was an 02' 4.6L. Just checked my 96' 5.8L and the whole valve is removable too. BUT both of those had a hex for a wrench on the valve, and I can clearly see the connection is threaded on my 96'.
What truck is this on? EDIT, just saw the other thread, 96' 460.
