The building of "Babe the Blue Ox"
#736
#738
#739
#741
#742
#743
Darin also made a mount for my dieselsite filter base on the firewall. The kit came with a alternator mount and the IC pipe was in the way. I never thought of looking at the SD filter kits, that might be the way to go if you have a IC. I don't know why but the picture of the billet thermostat housing is upside down but this gives you an idea of that.
Brian, no broken bolts! But, I screwed up and when I put the WP back on one of the electric taps on the passenger side got stuck under the WP and I didn't notice it. Had a leak of course and Darin discovered what I had done, loosened some bolts and pulled it out. Lucky it didn't tear the gasket and no leaks now.
Nate, the EGT's are at least 200° less, maybe a little more. I'm using Gearheads performance tune which seems to have as much power as the II's used to but I can defiantly stay in it longer. With no noise now (hopefully) I'll be able to really test it out today, I have 320 miles to go.
#744
#747
You guys did say it was ugly! Up high in the seam area it's still kinda tight, there just isn't much room on that truck. I cut up and out as much as I could. The reason I made the tunnel so far down is I wanted to get the dp/exhaust away from the trans line and crossmember too. It was laying right against the trans line, and just off the crossmember. With the tunnel that far down I was able to turn the dp a little for more room. That made it real close to the floor down farther, so I just kept on cutting! I hope it stays in that position and doesn't rotate on him. I think it will, but we'll see.
#748
#749
