Holley tuning experts, come on down!
i have about 300 miles on my new combo and it runs great other than seeming to be lean in the transition circuit and accelerator pump circuit.
Combo is ; 400 .030 over, Aussie Cleveland heads ~ 10:1 comp XE 262 cam, springs, lifters, retainers and timing set. Stock distributor vacuum advance disconnected and re-curved with lighter springs - 12* initial. Edelbrock performer intake, brand new Holley 4160 vacuum secondary. Hedman headers, 2-1/2" duals with flow master 40 copies.
Seems to have an off-idle lean stumble when accelerating gently. I've backed the idle mixture screws about 1/2 turn out which helped a tiny bit. Seems to have a lean stumble sometimes when going WOT. Changed the squirter to a 35 and then later the pump cam to blue and re-adjusted the linkage.
Thought the WOT acceleration was good, checking from a standing start. Then I went WOT on the interstate on-ramp and it stumbled. Let out a little and got back in it and it cleared up and went.
Idle is not overly rich, I'm thinking about backing IMS screws out more. Problem is worse when the motor isn't fully warmed up
Why is your vacuum advance disconnected. For street driving you should use it. You might have to retune after you hook it up. I was recently having the same kind of trouble with off idle response. Tried adjusting the idle mixture a bit with no response then found a bad diaphragm in the advance canister. Replaced it and had to adjust timing due to slight part difference and retuned idle mixture problem went away.
Vacuum advance is disconnected because I changed the distributor mechanical advance springs for lighter ones and am worried about pinging with the high compression. It's a stock distributor and not new.
No offense, but if I have a lean stumble I think adding more timing will make it worse, not better. Your bad diaphragm probably caused a vacuum leak; hence the stumble.
I don't think I've ever had an "new, out of the box" Holley perform perfectly. I mean, they are sized the same for a million different engines. If your having a "lean" stumble, and your positive it's not timing related, she needs more fuel. Increase the jet size? Your already are pumping more fuel out of the accelerator pump? Did the accelerator pump mods change anything?
Haven't had a chance to look at this further guys. Playing with the accelerator pump certainly helped the WOT stumble and I haven't noticed the slow acceleration stumble for a while. Seems it only does it when I'm putting around
Xwarrior86
42
09-13-2018 06:33 AM
charles jones
11-10-2006 07:45 PM
fly-fi$herman
09-14-2004 12:06 PM
