Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-01-2003, 08:02 AM
bigjons bigjons is offline
bigjons is starting off with a positive reputation.
Exclamation Air Bag code 27 on 1999 F150 Lightning
Hi everyone. Im new here & I have a problem. My airbag light on my 1999 F150 is blinking code 27. Also when it first started doing this I heard some relay near the center/left of the dash clicking on & off. Now, no matter what position I put the key switch on the dash to turn off the passenger airbag, the indicator there stays off and the airbag light stays on/blimking. It blinks 27 3 times then stays solid. Ive checked the output of the switch, it appears to be working properly, with different resistance outputs for different key positions. Ive seen the LED light up before, and yesturday when I was fiddling around with it. It lit up and the airbag light went out. I got so excited that I moved the switch to the on position, and it relapsed back to its old ways.
Any ideas on this?
Thanks alot
Ryan
  #2 (permalink)
Old 08-01-2003, 07:37 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Hi Ryan and welcome to FTE
I think you've got a bad PAD (passenger airbag disable) switch.
There are 2 different trouble codes that will cause a 27 light flash code. Your next step should probably be to get it scanned for codes to lead you in the right direction.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #3 (permalink)
Old 08-04-2003, 11:05 PM
Ghost_Rdr2000 Ghost_Rdr2000 is offline
Ghost_Rdr2000 is starting off with a positive reputation.
Talking Air Bag code 27 on 1999 F150 Lightning
Hello,
I have a 2000 Ranger and had a code 27. I found this fix on here, so I copy and pasted it in here. I got the parts from Radio Shack and did everything it says to do on here and it worked great for me. cost me $3.50 and my time, it was very easy to do.
Good Luck and Blue Skies,
Ghost _Rider
Here is a possible fix for a flashing airbag code 27. The problem was on a 2000 Ranger (out of warranty of course) , but should apply to Explorer and other Ford trucks as well.
Problem: After ignition switch turned on, airbag lamp on dash flashed code 27 several times, then remained lit.
Explanation of code: Fault in PAD (passenger airbag disconnect) warning lamp circuit.
Most probable cause: Burned out light bulb in PAD unit
Pinpoint tests were found in Ranger forum, a non-specific fix was posted in the F150 forum. Poster in F150 stated that bulb was not available from Ford, but you could buy the whole unit for $70. Not sure about you all but a $70 light bulb sounded rather steep to me.
Items required: Source is Radio Shack
1. RS part # 276-351 5MM Yellow LED 2.1 Volt 20 MA (2 in package)$2.49
2. RS part # 271-1325 2.2K ohm resistor (5 pack) $.99
Procedure:
1. Remove the PAD switch housing cover plate by prying it downward and popping it off.
2. Remove 3 sheet metal screws holding PAD housing to dash, unit should drop down.
3. Remove electrical connector from PAD unit by pressing release tang on top side and pull connector out.
Remove 2 screws holding PAD unit to housing, and remove
4. Using a small screwdriver, pry the top of the PAD unit cover off. Start at the backside next to where the wire connector inserts. Be careful not to break plastic retainers.
5. Remove the circuit board from the PAD key housing (Just lift it up)
6.Using a voltmeter set on 10X Ohms scale, measure across the lamp leads. If no deflection of meter is seen, lamp is open (burned out.
If meter moves, then a fault in the wiring is indicated.
7. Using a small pencil soldering iron, remove the lamp from the circuit board.
8. Holding the circuit board so as to orient the components up and wiring connector away from your body, solder in one of the LED's.
The LED should have 1 lead longer than the other, place the longer lead to your left and solder it in place.
9. Flip the circuit board over to expose the wiring path side.
10. Using an exacto knife or other cutting instrument, cut a hole in(open up) the wiring path between the outermost LED wire and wiring connector.
11. Solder one of the resistors across the just opened up wiring path.
If you did all this right, you can plug the board into harness and test by turning the key on. The LED should light momentarily during the airbag test sequence, then extinguish. Codes should not flash on the dash lamp. If all this is OK, then reassemble all parts, and you just saved yourself 70 bucks.
If the LED does not light, double check that you got the polarity of the LED correct.
Thanks to all on the Ranger forum and F150 forum for the help.
Shame on Ford for the sloppy engineering (or intentional gouging) as the case may be.
Dialtone
  #4 (permalink)
Old 08-05-2003, 12:46 AM
Racerguy's Avatar
Thanks for the tip
__________________
Forum Guidelines
this space for rent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
